February 05, 2026, 10:49:17 PM *
Author Topic: knobbed bolts for saddlebag  (Read 1647 times)
« on: October 11, 2012, 06:09:30 PM »
I want to remove my bags quickly, without tools.  I read that some have used quick release pins but they are hard to find and spendy.  I remember somewhere reading that someone had found perfectly threaded bolts with plastic knobs pretty inexpensively.  I think he said something like ten bucks for all eight saddlebag bolts.  Sounds like that would be a good way to go.  Has anyone found these?  Anyone have any idea what the bolt/thread size is for the (Tourer) saddlebag bolts?
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: October 12, 2012, 06:06:20 PM »
Two Brothers Racing used to sell a kit that had eight springpins and a drill bit to drill the threaded holes to fit the pins.
If you can get a "McMaster Carr" industrial catalog, they have them. They are about $3.00 apeice.
ALWAYS QUESTION AUTHORITY!
Oklahoma_Valk
Central OK
« Reply #2 on: October 12, 2012, 06:48:43 PM »
My local Tractor Supply has knobbed bolts. Would work perfect. You might check your local hardware store.
Im not sure of the bolt size. Just take one of them in to your local hardware store. I'm willing to be you'll find what you're after.
Let those who ride decide.
forjj
Luray, VA
« Reply #3 on: October 12, 2012, 06:56:07 PM »
You can also get knobs that have a female hex in them, to accept a bolt.  They are usually cheaper than the knobbed bolts, but either way, I agree with the local hardware store idea.
jj
2000 Interstate Blue/Silver
2005 Corvette
1989 F250 Diesel
1979 Ford 1100 Diesel Tractor
"I don't know where I'm going, I see no reason in being late"
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #4 on: October 13, 2012, 03:22:20 AM »
I believe the bolts are a 6x28  cooldude
« Reply #5 on: October 13, 2012, 09:17:31 AM »
Found them online, thanks.  It looks like they have about everything bolt and fastener wise.  Something like this
http://www.mcmaster.com/#plastic-head-thumb-screws/=jpcvi1
would probably be great for the purpose, but I can't tell if they have the right size.  I'll print this page and see if I can find them locally.
Momz
« Reply #6 on: October 13, 2012, 12:41:46 PM »
McMaster Carr has "Spring Pins". They have a pin in the middle of a tee shaped head. When you depress the pin, it allows two locking balls to retract.
http://www.mcmaster.com/#spring-loaded-quick-release-pins/=jpfl6w
You can use those knobed screws, but the spring pins would be my chose.
« Last Edit: October 13, 2012, 12:47:25 PM by Momz » Logged
