February 05, 2026, 10:55:45 PM *
Author Topic: K&N foam?  (Read 2075 times)
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« on: October 14, 2012, 08:13:18 PM »
I have a K&N air filter I want to donate to a neighbor.  It's been sitting in my shed for a bunch of years and the foam piece that is supposed to sit on the filter is deteriorating.  I checked the K&N site but they don't sell a replacement.
Has anyone used other foam?
6tigo
Member #655
Melbourne Fl
« Reply #1 on: October 15, 2012, 04:12:48 AM »
http://www.knfilters.com/airforcewraps.htm
If you ordered the correct width round one you could cut a piece to length.  Price is outrages for a piece of foam for your "Life Time Filter".
Last time I serviced mine I noted it was starting to go.
Four boxes keep us free:
The Soap Box, The Ballot Box, The Jury Box, and The Cartridge Box.
"Any man who thinks he can be happy and prosperous by letting the American Government take care of him; better take a closer look at the American Indian."
Henry Ford
fiddle mike
Corpus Christi, TX
« Reply #2 on: October 15, 2012, 04:47:13 AM »
« Reply #3 on: October 15, 2012, 05:33:01 AM »
Had the Valk for nearly ten years and the K&N without the foam has been in there since day one. Never caused a problem, plugs look fine, mileage in the mid-upper 30's....if I behave.
mmurffy03
03 standard
toms river new jersey
« Reply #4 on: October 15, 2012, 08:14:44 AM »
most owners use the filter without the foam insert
Farther
Quimper Peninsula, WA
« Reply #5 on: October 15, 2012, 08:17:43 AM »
You maybe right but I am wondering where you got your information or is this just your opinion?
~Farther
fiddle mike
Corpus Christi, TX
« Reply #6 on: October 15, 2012, 08:24:22 AM »
The K&N in my bike was purchased 10-12 yrs ago came without a  foam pre-filter.  The one in question was purchased years later.
I'm giving some thought to trying that green foam that goes in lawn mower air cleaners.
sugerbear
wentzville mo
« Reply #7 on: October 15, 2012, 09:00:45 AM »
haven't had a pre-filter on mine ever.
Momz
ABATE, AMA, & MRF rep.
« Reply #8 on: October 15, 2012, 09:10:04 AM »
Your bike will run just fine without the foam,.....guaranteed!
ALWAYS QUESTION AUTHORITY!
jad
N. Atlanta Ga
« Reply #9 on: October 15, 2012, 01:08:08 PM »
I agree that you may not even need one but just to be sure I contacted K&N and talked to a rep explaining that I purchased the bike used at that time 3 years in 07.  I wanted to purchase the foam prefilter because the old one was breaking down and about to handgrenade on me.  He at first didn't know what I was talking about but I think I had a  part number then.  He ended up sending one to me free of charge.  I do use the prefilter still and Moya still runs like a new bike.
just my .02 Cents.    cooldude
John now in LA.
98 Burg & Cream Tourer
« Reply #10 on: October 15, 2012, 01:13:26 PM »
242K+ miles on MGM and he has never had that stinkin foam filter in it.
Can get  upwards of 40 mpg if I don't get too heavy on the right handlebar.
« Reply #11 on: October 16, 2012, 08:47:48 AM »
Calling on my memory here - the prefilter was created to add restriction so the cleaner would have the same airflow as OEM, to prevent any difference in tune on the mixture.  So they make a filter that breathes better - than provide the ability to defeat that improvement thereby addressing that objection so as not to lose sales.  The prefilter also increases the incidence of filter maintenance.  Again from memory - IIRC - maintenance interval of the K&N is (I think) 100k miles.  OEM is a fraction of that.  I just checked mine recently, which had around 25k since last cleaned, but I had the tank off anyway, so I said check it while it's easy.  It was not very dirty, could have easily gone another 50k before cleaning.
I've run mine sans prefilter for 12 years or so.  Runs just great - but then I'm at high altitude where the mixture is dead on anyway, not running lean like low altitude causes.
Led
Wisconsin
« Reply #12 on: October 16, 2012, 11:51:39 AM »
I never used the foam.  I had a feeling I would have to service the "foam" part of it, WAY more often, than an OEM filter!!  Kind of would defeat the purpose, of switching to the K&N......which is LESS........filter service??  JMO........
My Bike was always jetted a little to "fat" for the OEM filter, and it finally came time to change the air filter, so dropping in the K&N was the "perfect" filter, to even things out.........runs PERFECT!!!!!
 Cool
Tropic traveler
Silver Springs, Florida
« Reply #13 on: October 19, 2012, 06:05:27 PM »
Bought a K&N for the '97 & it came sans foam. Called K&N and the rep said the foam pre-filter makes it flow very close to a stock filter which is the way I wanted it & sent me one for free. Over 40K & one cleaning all is good. I've had K&N's on many of my hot rods & race cars over the years... very familiar with them in use & concept.  cooldude
'13 F6B red for Kim
