April 30, 2026, 09:45:14 AM
Texas Chapter
(Moderator:
Daniel Meyer
New aux fuel tank mounting ideas
Topic: New aux fuel tank mounting ideas (Read 1887 times)
SideCar
Bikers don't need shrinks!
Colleyville, TX
October 18, 2012, 05:26:34 PM »
Ok. I got my new aluminum tank in to replace the leaking plastic one. Here's the basic look
http://www.tourtank.com/TourTanks.html
I got the 8 x 16 version with the center fill and outlet.
I'm thinking of how to mount it to the rear rack where I have the old, smaller tank. I mounted it on a small piece of plywood fastened to the rack. Not attractive but functional.
I'm thinking it would be good to have a wider mount with this slightly wider tank. Probably should still be raised a little bit like the one on wood to make sure it flows.
Ideas?
Come Ride to Save a Child's Life
http://www.curethekids.org/rideforkids/
SDS
OKC
Re: New aux fuel tank mounting ideas
October 18, 2012, 06:13:21 PM »
I've done this in the past with a rear rack. Be really careful and inspect the rack often. I didn't realize how much weight the fuel cell would add and how that would stress the welds on the rack. If you have some way of using straps to lift weight off of the tank and up onto the back rest that might help.
I really liked the extra range the aux. tank offered but there were a few issues to overcome.
Good luck with it and please post pics after you get it mounted.
SDS
www.sdsknifeworks.com
5_19
Dublin, Texas
October 18, 2012, 06:15:40 PM »
I could have plenty off ideas. Picture would help!
IBA # 45723
2009 BMW R1200 GSA
SideCar
Colleyville, TX
October 18, 2012, 07:01:08 PM »
Thanks, guys. Picture of the tank is at that link so you can also see the kinds of strap mounts. Here is a pic of the location for the tank. The fuel tank will go where the gnome is
https://picasaweb.google.com/lh/photo/gekRt_GJqhjDPp8Zl8eCvFfphgkhJOv3Qkdq_4erPhI?feat=directlink
but the extra hands won't be there to hold the tank on. Good point on the weight. I calculated that this tank with fuel will max out at about 30 pounds where my current one is just over 1/2 that. What welds gave you the problems?
SDS
OKC
October 18, 2012, 07:21:43 PM »
It was on a Kaw. Vulcan Classic and it was the main welds where they branched off horizontally from the back rest.
30 lbs. bouncing up and down on the highways puts a LOT of stress on those joints. Just be sure to check them and like I was saying (probably not very well) if you can figure out some way to pull straps up over the back rest vs. strapping it "down" onto the rack. That might lift the weight off of the rack and help over time.
SDS
October 18, 2012, 07:37:36 PM »
Hahahaha, I guess you have seen TJ's aux tank?
Ur but won't last as long as the fuel.
Hay
