February 05, 2026, 10:55:31 PM *
Author Topic: Speedometer cable broke!  (Read 1454 times)
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« on: October 18, 2012, 08:21:06 PM »
Yep, broke clean in two about 6 in up from the front wheel housing.  So, Motion Pro replacement or Honda inner cable only?
If you have ordered from Honda, do they keep these in stock?
Farther
Quimper Peninsula, WA
« Reply #1 on: October 18, 2012, 09:19:57 PM »
I recently replace both the cable and the outer cable.  Was way less expensive than I thought it would be and I didn't know if the inner cable messed up the housing when it broke.
~Farther
Bill anderson
« Reply #2 on: October 19, 2012, 03:05:29 AM »
When my speedo cable broke it tore up the outer also so I had to replace the whole thing.Honda dealers generally don't stock any parts they order parts as needed.
« Reply #3 on: October 19, 2012, 05:20:23 AM »
I just replaced the inner cable, very easy to do, and have had no problem with it.  Hoser
« Reply #4 on: October 19, 2012, 08:14:49 AM »
Lubrication is an important player with speedometer cables.
A little grease can make a world of difference.
« Reply #5 on: October 19, 2012, 12:54:10 PM »
Ricky-d, I use slippery Spray Silly Cone.
Also use it on the bottom of my garage doors so they don't freeze down in the winter.
GreenLantern57
Rock Hill, SC
« Reply #6 on: October 19, 2012, 02:05:12 PM »
Well, when putting the housing back on so rain and dirt would not get in. I tightened the screw down too much and broke the dang plastic loop.  I stopped at the shop after work and ordered the  whole unit from Motion Pro anyways. No shipping and it should be in Monday.
I do not think the sleeve unit recieved any damage.  I have rebuilt a dozen car cables for me and friends. I have had to replace lots of inner cables, but several had to be completly replaced when the cable frayed and made a mess of the sleeve.  I have never seen one broken clean like this one. Pretty strange cause even the wire wrap was a clean break.  I use dry graphite in my speedometer cables when I rebuild.
« Reply #7 on: October 19, 2012, 04:21:39 PM »
Well, when putting the housing back on so rain and dirt would not get in. I tightened the screw down too much and broke the dang plastic loop.  I stopped at the shop after work and ordered the  whole unit from Motion Pro anyways. No shipping and it should be in Monday....
I did the same thing after lubing the speedo cable for my 1983 CB 1000C. So I order a complete replacement from Motion Pro. That will teach us for being so "heavy fisted". tickedoff 2funny
My rides:
RP#62
Gilbert, AZ
« Reply #8 on: October 19, 2012, 06:07:53 PM »
I'm with Ricky on this one.  A very similar setup is used for the RPM indication on light aircraft.  Many call for the teleflex cable to be periodically removed, wiped clean and regreased with moly grease.
-RP
Momz
ABATE, AMA, & MRF rep.
« Reply #9 on: October 20, 2012, 12:55:43 PM »
-RP
I used to work for Teleflex Inc.
Just replaced the speedo cable assembly on Pams bike. It cost only $18.50 including shipping from Amazon.com.
« Last Edit: October 20, 2012, 12:59:15 PM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
