chuckie
« on: October 23, 2012, 06:55:54 AM » |
I am curious to know who has high mileage Valks out there and never had a problem with reed body etc. Don't like to do stuff that ain't necessary. Desmog is not a biggie but also maybe overkill and not really necessary. Thanks Chuckie
« Last Edit: October 24, 2012, 08:39:47 AM by chuckie »
« Reply #1 on: October 23, 2012, 07:14:13 AM » |
I have 132K not desmogged. I would not have a problem about doing it if I thought it would help something that was a problem, but, so far there hasnt been any need so there hasnt been any changes to the smog system
« Reply #2 on: October 23, 2012, 07:16:00 AM » |
Have not had any problem since I did a complete desmog about 75000 miles ago. Actually didn't have any problems before that either. I'm still glad I did it, got rid of all that junk under the tank and will never have a vacumn leak.  Hoser
« Last Edit: October 23, 2012, 07:19:26 AM by Hoser »
« Reply #3 on: October 23, 2012, 07:53:35 AM » |
That is the same reason I did a desmog and I feel it is the most common reason why most do a desmog.
The reduction of possibilities of vacuum leaks is a good thing.
« Reply #4 on: October 24, 2012, 08:09:08 AM » |
I have 168,000+ on my Standard which has never been desmogged. The only problems I've had are vacuum leaks in the lines solved by replacing or trimming the lines.
I'm going to get around to doing the desmog sometime (soon, I hope).
Rio Wil
« Reply #5 on: October 24, 2012, 08:37:41 AM » |
170K on my I/S and fully smogged  No intention to desmog as of this time. Also, still have original vacuum lines and air filter....  And, I refer to my bike as medium mileage...
« Last Edit: October 24, 2012, 08:40:27 AM by Rio Wil »
JaysGone
« Reply #6 on: October 24, 2012, 05:47:32 PM » |
170K on my I/S and fully smogged  No intention to desmog as of this time. Also, still have original vacuum lines and air filter....  And, I refer to my bike as medium mileage...  Original air filter???? 170K..........how is this possible? My 99 mileage unknown had such a dirty filter in it. It hardly ran at idle when I first got it going. I put in a new filter OEM and its run pretty good since. Just being inquisitive here nothing else.
1999 Valk - SOLD 2005 Yamaha RoadStar 2010 GoldWing with Motor Trike Kit
Rio Wil
« Reply #7 on: October 24, 2012, 06:46:59 PM » |
The design of the air box intake lends to a first stage cleaning of the intake air by essentially centrifugal force (might be a better word for the action of air and particles having to turn a 180 degree corner to enter the box). Anyway it has even been to Alaska and ran some 500 miles of dirt and gravel roads, I did take it out and vacuum it off, thought it would be really dusty....but wasn't. So, will check it again at 200K and probably do a plug replacement .....will have 100K on the plugs at that point. Might as well confess the rest of my sins.....I still have the original brake and clutch fluids, I did change the coolant once at 100K with a non-silicate fluid. Still have Honda brake lines, not steel braid and haven't failed to stop my bike satisfactorily even once. Gone through a crap pot of headlight bulbs, the automotive ones don't seem to last as long as the OEM. Oh, the brake fluid has not gathered too much water as it is hygroscopic,,,,,I just use a 5 gallon bucket as a reservoir...  ...hehehe, just kidding. I suspect that if a bike is used regularly year round the heating of the calipers will basically keep the fluid pretty dried out......thats my story and sticking to it... oh yeah, I get 32-40 mpg depending how much I twist the throttle.....got 17 mpg one time headed into a 40 mph wind and running 90+ out in New Mexico. Got 60K on my Pirelli P4 car tire, replaced it with an identical one a couple of weeks ago. Still have the original rear wheel bearings, changed the fronts at 150K due to one being a bit rough. (as an aside, contrary to a loudly proclaimed opinion, the 1800 Goldwing does not use double roll bearings in the final drive nor the front wheel as a upgrade to this single roll bearing in our Valks) Posted picks of the bearing after opening it up to see the failure mode....pitted... Never use more than a gentle water spray to wash the beast, usually no soap at all. Wax it occasionally with what ever comes out of the cabinet when I reach in..., Ok, now this is my story and am sticking to it
JaysGone
« Reply #8 on: October 24, 2012, 09:09:42 PM » |
Here Im having 2nd thoughts about using a 14 year old bike for a trike. Hope I get somewheree near your numbers.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #9 on: October 25, 2012, 11:09:16 AM » |
THE BEST ONE THING THAT I DID TO MINE WAS A DESMOG.....GOT RID OF ALL MY VACCUM LEAKS.
Joe Hummer
Arnold, MO
« Reply #10 on: October 25, 2012, 12:29:08 PM » |
Not as many miles as some that posted on here but I have 103k on my still smogged bike. No problems from vacuum leaks and only on my second set of vacuum lines. Replaced them a few years ago with thicker-walled 5/32" ID Vacuum/Washer Fluid lines. Can't use the stock style clamps but I don't think you need to as the lines are being sucked onto the barbs. Not like they are going to blow off or anything.
Joe
1999 Valkyrie Interstate You pay for the whole bike, why not use it Jerry Motorman Palladino
Regis
« Reply #11 on: October 25, 2012, 04:25:21 PM » |
I desmogged mine because the Pair Valve had an annoying "chirp" at low speeds that bugged the shot outa me . Couldnt see buying parts to put new reed valves in .
Dougs2000IS
« Reply #12 on: October 25, 2012, 04:35:03 PM » |
i de-smogged at 60K. I was amazed at the power increase, but I think I had a vac leak.
2013 Victory Vision Arlen Ness 2000 Valk Interstate (sold) 1997 Ford F150 2006 Honda Civic Hybrid Go Packers
« Reply #13 on: October 25, 2012, 06:24:57 PM » |
Stude31 helped me do mine.2-3 years ago. Hoser
PharmBoy
« Reply #14 on: November 01, 2012, 06:00:25 AM » |
To each his own! However, to those who want to keep their bike as it came from Mother Honda, I have a great big box full of parts from 5 or 6 desmoged, low mileage Valkyries. Just send me a PM on what is needed. Personally, I would not trust any of the vacuum lines, but they are yours if you want them along with anything else removed for the actual cost of the shipping...Jim
A politician is a fellow who will lay down your life for his country. ~Texas Guinan 4th Infantry Tet Vet 99 Interstate 97 Bumble Bee 97 Red & White
