February 06, 2026, 12:48:42 AM *
Author Topic: Spark Plug Wires  (Read 2827 times)
Big Tom 10628
Surprise AZ.
« on: October 23, 2012, 07:30:58 PM »
Is HDL kidding me, $140.47 for the Six plug wires? It's a good thing they last for 13 years...
1999 Valkyrie Interstate
2006 Gold Wing
« Reply #1 on: October 24, 2012, 06:21:27 AM »
Im not surprised at that price.  But you better make sure what you are buying is a complete assembly.  The Honda fishe seems to have the parts all broke up, so the wires may just be wire.  It looks like the boots "caps" are listed seperately.
Big Tom 10628
Surprise AZ.
« Reply #2 on: October 24, 2012, 07:05:35 AM »
Yer right. The fiche says "Cap 1-6 ignition" but the picture shows the entire piece, Two caps and a wire. I guess that it will require a phone call or a visit to the stealer.
2006 Gold Wing
BonS
Blue Springs, MO
« Reply #3 on: October 24, 2012, 07:59:08 AM »
If your caps are okay then $15 at the auto parts store will get you all the 7mm wire you need. There's a how to somewhere on the board.
« Reply #4 on: October 24, 2012, 08:10:24 AM »
When changing out spark plug wires, a good thing to do is use a volt/ohm meter to note the resistance in the stock wires.
When considering new wires, the ohm rating of the new wires should necessarily match the rating of the stock wires.
The reason to do this match is that the electronic ignition is a sensitive instrument and could possibly be compromised if wrongly rated wires are introduced in the system.
I'm not saying this is guaranteed to happen, but it is a real possibility and should not be ignored out of hand.
« Reply #5 on: October 24, 2012, 08:40:05 AM »
Here ya go, compliments of yours truly. Did this a few years ago and have had no problems. The link is found in Shop Talk, the job is rather easy just don't be in a hurry. I used Accel yellow wires, 7mm, p/n 3008 universal with straight boots.
http://www.valkyrieriders.com/ShopTalk/plugwires.pdf
Big Tom 10628
Surprise AZ.
« Reply #6 on: October 24, 2012, 09:15:02 AM »
Thanks,  that looks like even I can do it......lol
2006 Gold Wing
G-Man
White Plains, NY
« Reply #7 on: October 24, 2012, 09:24:01 AM »
Wow, man....Thanks!  This is something I might try.  Dealer near me wants $156 for the set of spark plug wires.
art
Grants Pass,Or
Grants Pass,Or
« Reply #8 on: October 24, 2012, 11:11:02 AM »
Accel wires.I've had them for four years cooldude cooldude cooldude
BonS
Blue Springs, MO
« Reply #9 on: October 24, 2012, 01:38:34 PM »
Our bike uses 7mm copper wires - not resistor wires. Buy accordingly and you won't and can't have any issues with regard to the wires.
Blackduck
West Australia
« Reply #10 on: October 24, 2012, 06:01:31 PM »
2 ways to go, retain the resistors in the plug caps and use plain wire or delete the resistors and use resistance wire.
Have been running resistance wire for years with Standard, IS and Dyna modules no problems.
The question is why are you changeing plug leads? Being plain wire they very seldom give any trouble.
Big Tom 10628
Surprise AZ.
« Reply #11 on: October 24, 2012, 06:42:37 PM »
The answer is, because after 13 years I am hearing an ignition tick from my CB. Seldom does not mean never.
2006 Gold Wing
Blackduck
West Australia
« Reply #12 on: October 25, 2012, 02:22:55 AM »
Sounds like a good place to start checking, do you have any other Valk owners nearby to try swapping leads. At those prices I would want to be certain of the cause before spending that.
Thought the bulk replacement wire is not that expensive.
On a side note does it have the correct sparkplugs?
Cheers Steve
« Reply #13 on: October 25, 2012, 04:55:02 AM »
could be just the resistor in the plug cap. they can be removed and replaced. there have been some posts although rare of a resistor going bad.
Tropic traveler
Silver Springs, Florida
« Reply #14 on: October 26, 2012, 06:24:57 PM »
Heed whatever John Schmidt says about the plug wires.
One of the sharpest looking & running Valkyries on earth is owned by John!  Wink
That's him on the right with Trick Rick, another good Valkyrie wrench!
'13 F6B red for Kim
« Reply #15 on: October 26, 2012, 08:26:09 PM »
Good grief Eddie, where did you dig up that picture? Isn't that the buffet there at the Sunshin Mall, I remember the shot being taken just don't recall the year...Bike Week this year or last maybe? I'm at least 30 lbs. heavier in that pic compared to now, and Rick is still just as ugly.  2funny 2funny
Rick old friend, sure wish you lived a couple hunert miles closer. Rita asked about you after this past weekend lunch ride. I told her you were still just as harmless as ever. She just gave me a funny look!  cooldude
« Reply #16 on: October 27, 2012, 09:15:00 AM »
Resistor plug caps and resistor plugs, and plug wires with engineered resistance work in unison with each other and I am not positive one can replace the other and negate the need for some individual part.
The whole thing is wrapped up in EMI, GPI, RFI, and a host of other electrical properties which are all interrelated and have influence over all the electrical systems in our Valkyries.
Unless you a thoroughly versed in this area of expertise (I am not) there are consequences connected with making modifications than can affect the different operations of the electrical systems on the bike.
That's why I suggest to stay within the boundaries already defined by the stock components.
« Reply #17 on: October 27, 2012, 01:05:01 PM »
Ricky is right on his approach, that's why I used stranded wire when I made the change since the OEM is stranded. And, it's why I proceeded to take the time and go through the trouble of using the same resistors and plug caps. It involved unsoldering the old wires and resoldering the new ones in place.  As a result, I've had zero problems with my setup.  cooldude
