January 30, 2026, 09:22:14 AM *
Author Topic: Rotella synth  (Read 7399 times)
Scanner
Tacoma, WA
« on: June 12, 2009, 04:25:36 PM »
Did an oil change last night using Rotella Synth 05-40.  Nice....seemed to really quiet Bertha down and she runs smooooth. Highly recommended.
Reality - it's nice here, come visit sometime!
Bladedog
Lompoc, CA (Central Coast)
« Reply #1 on: June 12, 2009, 04:36:03 PM »
Did 120 miles after switching to the Rotella, and already noticed the smoother shifting.  We'll see if there's any fuel economy difference when I fill up again.
It's easier to get forgiveness than permission.
thewoodman
Bradenton, FL
« Reply #2 on: June 15, 2009, 09:22:57 AM »
I started using the Rotella T Synthetic 5-40 about 16,000 miles ago with good results, especially better shifting compared to the Castrol 20-50 I'd been using in the GL1200s I had for the previous 20 years. The closest WalMart stopped carrying it, (though I did find it later at a different store) so I bought some Mobil 1 5-40 synthetic for turbo diesel trucks. I just did an oil change yesterday and rode to work this morning like I do most every day and it shifts even smoother. The motor seems quieter too. I wonder why? I just love these oil threads.
TheWoodMan
godfire
Republic of Texas
« Reply #3 on: June 15, 2009, 09:54:42 AM »
I've used Rotella Synth for the last 25K miles. The local Autozone carries it as well as Wallie World.
Ride Safe
Ride Often
aviaator
No. Virginia
« Reply #4 on: June 15, 2009, 11:04:13 AM »
Keep in mind Rotella synth is a diesel oil and is LOADED with detergents.  If you have any oil leak, Rotella will find it and exploit it.  I used Rotella on my Valk once, found two oil leaks i didn't know existed Angry (one was the shifter shaft seal).  Never used it since.
Same thing on my gasser Mercedes -- oil leaks galore once I switched to Rotella!
It's not bad oil; just that it will leak out of even the smallest pinhole (that you didn't know existed).
Mike (aviaator)
'97 Tourer
'00 I/S
VRCC 27632
Southern Cruisers Manassas, VA Chapter
SANDMAN5
Mileage 65875
East TN
« Reply #5 on: June 15, 2009, 11:11:59 AM »
Keep in mind Rotella synth is a diesel oil and is LOADED with detergents.  If you have any oil leak, Rotella will find it and exploit it.  I used Rotella on my Valk once, found two oil leaks i didn't know existed  (one was the shifter shaft seal).  Never used it since.
On the other hand....ain't it better to find small leaks before they become big leaks? I've
used Rotella in both my Valks and ain't neither one dripped a drop. Total of about 20,000 miles.
aviaator
No. Virginia
« Reply #6 on: June 15, 2009, 11:18:25 AM »
The point I was trying to make was: most [older] engines have areas around gaskets/seals/etc that are not leaking b/c they're "clogged" with sludge or some other type of engine grime.  A high detergent oil like Rotella will "unclog" it and create a leak where one previously did not exist - and might not have even started otherwise.
Glad to hear your Valks leaked nary a drop.  Others might not be so fortunate.
'97 Tourer
'00 I/S
VRCC 27632
Master Blaster
Deridder, Louisiana
« Reply #7 on: June 15, 2009, 12:32:28 PM »
I use it in everything I own, diesel and gas, truck, cars, motorcycles, lawn tractors, you name it.  Been that way for years, no problems.
daytona
Port Orange, FL
« Reply #8 on: June 15, 2009, 02:08:39 PM »
Mobil 1 15w50  cooldude Diesel eng for me. True synthetic! The rest are on crack!
Hydrocracked/Hydroisomerized = API Group III base oils. Chevron, Shell, and other petrochemical companies developed processes involving catalytic conversion of feed stocks under pressure in the presence of hydrogen into high quality mineral lubricating oil. In 2005 production of GTL (Gas-to-liquid) Group III base stocks began. Even though they are considered a synthetic product they are still mineral base stocks and counted as the mineral part of all semi-synthetic lubricants. Group III base stocks [with certain amount of mixture of PAOs and esters and Group V] are considered synthetic motor oil ONLY in the United States.[citation needed] Group III based lubricants are not allowed to be marketed as "synthetic" in any market outside of the USA.
Just started!
daytona
Port Orange, FL
« Reply #9 on: June 15, 2009, 02:10:33 PM »
Let the  tickedoff begin!!! Roll Eyes
Just started!
« Reply #10 on: June 15, 2009, 05:30:02 PM »
Don't know all the oil science behind it (or really care), but my Fat Lady didn't really quite down with anything I used untill I went with Mobil 20w-50 synthetic motorcycle oil.   cooldude
franco6
Houston, TX
« Reply #11 on: June 15, 2009, 08:09:53 PM »
to each his own ! cooldude uglystupid2
Enjoy the ride!
Airetime
Anacortes, WA
« Reply #12 on: June 16, 2009, 04:55:35 AM »
Mike (aviaator)
Too bad our synthetic oil selections have narrowed over the years due to the "Friction Modifiers" that have been added to our favorite oils (thanks epa)  tickedoff Although synthetic oils in general may contain detergents, the high majority of the time they do fine in our Valks. All we can work with is what we have and Rottella is one of the few oils left that works well. Chances are you would have had the same problems with any "synthetic oil" so you have to make your own decision, keep the sludge or fix what needs to be fixed.
Duey
Rochester, MN
« Reply #13 on: June 16, 2009, 01:30:22 PM »
daytona
Port Orange, FL
« Reply #14 on: June 16, 2009, 02:06:30 PM »
What ever works for U is what is the best! The 15w50 M 1 diesel has no modifiers just like the Rotella T but is real syn. cold start flowability is what we need, the Valk will never need the hi temp protection that syn is known for. $75.00 oil changes just aren't for me.
Just started!
Larry
Northeastern BC, Canada
« Reply #15 on: June 16, 2009, 04:04:29 PM »
I use 10-30 Mobil 1, not for high milage engines and find it works well fro me  Smiley . I can usually buy 1 Gal for about $28 and the filter about $10 for chrome. My friend had a mid-80's 1200 wing that used to use Rotella, he found he used oil which does not happen so much now since he switched to regular oil again. I sent him the infor from here on why the Rotella would seem to get consummed in his bike. He isn't one to fix stuff unless it REALLY needs it! So, for him a bit of sludge is a good thing. Tends to keep the leaks to a minimum.  Grin Also no more smell from the "Rosmella" when I'm following him and that's a good thing!
DeathWishBikerDude
« Reply #16 on: June 16, 2009, 06:49:53 PM »
I buy the cheapest synthetic I can find.
Super tech from wally world.
I change my oil every year,about every 5000 miles.
Doesn't make sense to buy the more expensive stuff.
Bike runs silently.
 coolsmiley
Duey
Rochester, MN
« Reply #17 on: June 17, 2009, 12:14:39 PM »
miles on.. I just keep an eye on the condition of the oil and change at the 8000 mile interval. I also use amsoil synthetic so I could technically go 25,000 if I really wanted to. I do in my car. The price of oil is a small factor in the maintenance of my Valk. Aint nothing to good for it!  cooldude
Airetime
Anacortes, WA
« Reply #18 on: January 16, 2010, 10:08:40 AM »
 ??? Gotta disagree here as "ALL" Mobil One oils have the dreaded friction modifiers in the new formulas according to the Tech Department at Mobil One. I emailed them a couple of years ago and asked them.
Farther
Quimper Peninsula, WA
« Reply #19 on: January 16, 2010, 10:24:53 AM »
Has anybody switched from the motorcycle specifric synthetics like Mobil 1 or Amzol to the car/truck synthetic versions and what was your experience?  I currently have the Amzol motorcycle oil in my Standard after running the Mobil 1 motorcycle oil.  I noticed no difference.  I can get the Rotella from a friend who is the Shell jobber (wholesaler) in my rural area.  No retailers carry the Rotella synthitic without the energy saver stuff.
~Farther
« Reply #20 on: January 16, 2010, 10:55:44 AM »
I used the Valvoline MC oil before. I then went to Mobil 1 and now the Shell. No problems. I'll stay with the Shell. I usually change oil before and after a big trip anyway.
My HD bud uses oil that he puts in work dump trucks in his E-glide. Sometimes he even puts the used oil in his bike. No problems.
Thunderbolt
Worthington Springs FL.
« Reply #21 on: January 16, 2010, 03:19:20 PM »
Don't know why, but it sure started to stink.  I dumped it back out and changed to Mobil 1 4T motorcycle oil.
sheets
Jct Rte 299 & 96, Calif.
« Reply #22 on: January 16, 2010, 04:10:13 PM »
 . . . been using the Rotella synthetic for a few years now.
No hits. No runs. No errors.
Works for me.  Yrmv, sheets
X Ring
VRCC #27389, VRCCDS #204
« Reply #23 on: January 16, 2010, 04:26:25 PM »
Sandman's engine got noisy when I put Rotella T synthetic at the last oil change.  Previously I've been using Mobil 1 MT 10W40; however, with it at $10/qt my next oil change will me Mobil 1 15-50.
Marty
Tropic traveler
Silver Springs, Florida
« Reply #24 on: January 16, 2010, 04:38:08 PM »
HMMMM. I was unaware until I read this post that other folks have experienced an oil smell when using Rotella 5W40 synthetic as well.  ???
I switched to Rotella 5W40 syn at 60,000 miles. All Honda GN4 10W40 dino up until 60K. I just chalked up the oil smell to the fact that my Valk is high mile, approaching 100K now.  HMMMM again!
I switched Kim's Valk to Rotella 5W40 at 14K. 21K on it now with no leaks or smell.
Anyways, I too noticed a slight improvement in shifting ease but no decrease in noise with Rotella 5W40. No leaks of any sort other than the obligitory shift shaft seal at 90K.  Roll Eyes
Terry, did you notice "the smell" more at cold start up than any other time??
Anywhoo, I change at 4K more because of the filter than anything else. The Rotella 5W40 synthetic is a bargain at $19 per gallon and always available at the local WallyMart.  cooldude
« Last Edit: January 16, 2010, 04:47:23 PM by Tropic traveler » Logged
'13 F6B red for Kim
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #25 on: January 16, 2010, 05:31:00 PM »
Thunderbolt
« Reply #26 on: January 16, 2010, 05:45:20 PM »
I had been using the Mobil 1 Red Cap and ran out of it and tried the Rotella just that one time.  I noticed when I was in Advance/discount auto the other day that Valvoline was selling a wet clutch compatible oil, I might try it next time.  The Mobil 1 4T is pretty expensive, even though I usually don't change until 5000 miles or so.
« Reply #27 on: January 16, 2010, 08:04:27 PM »
I use Amsoil 10w30/30 HD diesel oil.  Extremely smooth shifting oil. Have used most others incl rotella T.
PharmBoy
Lawton, Ok
« Reply #28 on: January 17, 2010, 08:03:12 AM »
I just can't resist!  Use whatever you think best.  It is your motorcycle.  I do not propose to chance anyone's mind on the oil they use.  This is only my experiences with the two bikes I now own.  I bought the first gallon of Mobil 1 Turbo-diesel 5-40 that I ever saw and now have it in both bikes.  It seems to run quieter and shift easier, but that may just be my interpretation.  Like the man said, "Yo pays yo money and yo takes yo pick".....JTL  Grin Grin Grin
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Tropic traveler
« Reply #29 on: January 17, 2010, 04:02:03 PM »
That's when I smell it also, at start-up. I wonder why that is.  ???
Anyways, it won't stop me from using the Rotella 5W40. I liked the Rotella 15W40 when I had my PowerStroke Ford & had heard good things about Rotella products from my fleet customers over the years. cooldude
I agree about the Mobil 1 being expensive!   Shocked  That's what I used in my R3 also.
'13 F6B red for Kim
X Ring
« Reply #30 on: January 17, 2010, 05:03:49 PM »
I noticed a smell starting up 1st time of the day since I switched to Rotella T but I couldn't find anything so I thought it was my imagination.  I'll agree Mobil 1 M/C specific oils are expensive, $10/qt, that's why I bought a gallon jug of Mobil 1 15W50 at Wally World for $22.
Marty
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #31 on: January 17, 2010, 07:17:32 PM »
I've always used the 5 40 rotella in mine along with the supertech filter. The longer filter. I think its the 3717. No problems.
Rio Wil
« Reply #32 on: January 17, 2010, 08:46:28 PM »
I switched to Rotella  5-40 after my clutch began slipping after a diet of 20-50 M1 for 90K miles. After 2K miles the slipping was gone, I can only presume the thinner weight oil flushed the clutch plates out.  The slipping was detected while acceleration full throttle in 4th gear at 4000 rpm and above.  I did a little test today, after 10K miles of Rotella, and still no slippage. The test was 4th gear, max throttle starting at 4k rpm....quickly snap in the clutch lever and release.  The engine rpm jumps to 6000-6500 and then quickly drops down to 4500 or so as the clutch bites again.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #33 on: January 19, 2010, 08:51:21 AM »
I started w/Honda's 1/2 regular 1/2 syn and used it until 20,000. Since then I have ran Rottela and the bike now has 68,000. No problems, no leaks.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
« Reply #34 on: January 25, 2010, 08:11:06 AM »
the Amsoil 10w40 and 20w50 auto oil has always been M/C rated and is still stated on the bottles last I looked. For marketing reasons, which did greatly increased their sales they put the same oil in M/C specific bottles.
Only until a few yrs ago did they start making a M/C specific oil which is on paper better than the org.
valkyriemc
NE Florida
« Reply #35 on: January 25, 2010, 05:20:57 PM »
Rotella 5w-40
http://en.wikipedia.org/wiki/Shell_Rotella_T#Motorcycle_usage
Veteran USN '70-'76
