ryord
« on: October 26, 2012, 12:20:09 PM » |
I would like to be able to mount it in the same place as plug and play as possible, If there is such a thing. Thanks in advance.
« Reply #1 on: October 26, 2012, 12:32:02 PM » |
About any route you go to get a legitimate traffic alert device will require the use of a relay. I guess that rules them out of the plug and play category. I would suggest either Big FB's quad horns http://bigbf.com/bigbf_shop/bigbf_horns/or the Wolo Bad Boy compact air horns http://www.wolo-mfg.com/air.htm
Chiefy
« Reply #2 on: October 26, 2012, 12:49:08 PM » |
I don't know of a plug and play horn that would be any louder then the stock.
What's going on? Is your stocker bad, and you just want to replace it? Or are you looking for something louder?
« Reply #3 on: October 26, 2012, 01:09:52 PM » |
I have the wolo bad boy on my Phatt Ghurl.  Had a guy coming up a ramp in a dodge diesel pick up on a cell phone A/C on and trying hard to replace me with his pick up.  One blast of that horn FINALLY made him realize i was there.  How do i know his A/C was on?? 95 degrees out and his windows were up.  Point being for as small as they are they have a large sound.  Check E-bay and Amazon-lower prices and that's where i bought mine-Amazon.  And at times i can fart louder than that stock horn.  RIDE SAFE.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #4 on: October 26, 2012, 01:54:40 PM » |
+1 on Big FB's quad horns http://bigbf.com/bigbf_shop/bigbf_horns/I have his duals and even they're loud enough to get everyone's attention. Saved my butt again just yesterday from someone in a cage who thought he wanted the same spot on the road that I already had. Woke him up pronto!
Daniel Meyer
The State of confusion.
« Reply #5 on: October 26, 2012, 02:21:06 PM » |
Big BF's Quads!
CUAgain, Daniel Meyer
« Reply #6 on: October 26, 2012, 03:02:14 PM » |
HD is plug and play depending on how you mount it. I had to add 4" of wire.
Disco
Republic of Texas
« Reply #7 on: October 26, 2012, 03:11:21 PM » |
Big BF's Quads!  +1! I went through two Stebel Compact Nautilus horns (same as Wolo Bad Boys) in two years. Not that I wore them out from overuse, they just didn't hold up to the hostile environment even though I mounted them from the sidestand cross member, upright, and behind the engine. Others have had better longevity than I did, so don't take it as gospel. After the second one failed, I went with BigBF's Quad Horns and couldn't be happier.
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
« Reply #8 on: October 26, 2012, 03:19:12 PM » |
The wolos and stiebel types of air horns do fail if put under the bike, I have not had any trouble since I did this. They need to be protected from road spray in wet weather Hoser
« Last Edit: October 26, 2012, 03:21:36 PM by Hoser »
« Reply #9 on: October 26, 2012, 03:40:48 PM » |
If you dont know of any plug and play that is louder than stock. Well sorry, you just dont know horns.
Farther
« Reply #10 on: October 26, 2012, 03:52:59 PM » |
If you dont know of any plug and play that is louder than stock. Well sorry, you just dont know horns. Got any suggestions or just comments?
Thanks, ~Farther
Chiefy
« Reply #11 on: October 26, 2012, 04:09:37 PM » |
If you dont know of any plug and play that is louder than stock. Well sorry, you just dont know horns. Well, you sure told me. I'm humbled. (Not)
« Reply #12 on: October 26, 2012, 04:26:10 PM » |
If you dont know of any plug and play that is louder than stock. Well sorry, you just dont know horns. Got any suggestions or just comments? Sorry but I lol at this one.
« Reply #13 on: October 26, 2012, 04:35:38 PM » |
No, Im sorry....ANYTHING is louder than stock. But I have a Stebel Im pretty sure its way louder than stock
Tropic traveler
Silver Springs, Florida
« Reply #14 on: October 26, 2012, 05:52:04 PM » |
IMHO ONLY.... car horns are the best route to go. I don't know of anything plug & play that has a good enough improvement over stock to bother with. Air horns have a slight delay & are expensive. Some are un-Godly loud & may defeat the purpose of keeping you safer by scaring the bejeezus out of car drivers.  A for sure consideration here in Florida! Car horns are cheap, durable, & are a familiar sound to inattentive 4 wheeled drivers albeit a tad louder than they were on the car. Mounted under the swingarm makes them louder than on a car. Six years & 50,000 miles & they still work great. Added bonus to mounting them out of sight under the SA is it cleans up the motor area of the Valk. Relay is a must but anything worth doing is worth doing right.  Welded a 5/16 X 1" bolt to the kickstand X-member to mount. Used a locknut to secure & pointed the horn openings to minimize splash but they still got drowned out once in a Florida toad strangler one day. Dried out a couple days later, still working fine! I've installed car horns on all 3 of our Valks, Kim's SS750, & even on my Triumph R3 {under the LH sidecover}. A bit more effort on the Rocket!   Again, just my opinion. BTW, the horns are from a early 2000's Lincoln Town Car or a Grand Marquis/Crown Vic. They have a neat V shaped bracket for easy mounting. Clip the wires up past the connector if you are getting a salvage yard set.
« Last Edit: October 26, 2012, 05:57:29 PM by Tropic traveler »
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
« Reply #15 on: October 27, 2012, 04:43:06 AM » |
car horns are the best route to goI think, without knowing for sure, that Big BFs horns are "car horns"... The best thing about them (other than that they sound good and loud) is that the spill out of the package with Valkyrie specific mounting brackets and installation instructions  -Mike
« Reply #16 on: October 27, 2012, 06:26:25 AM » |
I like my Stebel and Wolo installs. Put them under the tank by the petcock switch. Need to install a relay.
PharmBoy
« Reply #17 on: October 27, 2012, 06:46:43 AM » |
+1 on the car horns. Twenty bucks or less at the wrecking yard gets you a pair of horns of your choice and the mount for free. They are easy to mount by drilling one hole and taping it. Also, they are completely out of sight. A relay should be used, but that only comes up to the basic wiring 101. Quad horns are great also and come as a unit with wiring, but considerably more expensive...Jim
A politician is a fellow who will lay down your life for his country. ~Texas Guinan 4th Infantry Tet Vet 99 Interstate 97 Bumble Bee 97 Red & White
9Ball
« Reply #18 on: October 27, 2012, 06:59:09 AM » |
I found this link the other day....some were doing this mod to their Stebel air horns and someone stepped in and made these improvements. This allows you to mount the compressor in a dry, hidden location and the air horns can then be placed under the bike or behind the sidecover, as needed. This also allows a short burst with the stock horn with the adjustable 1/4 or 1/2 second delay. Seems to be a nice package. http://screaming-banshee.com/full-split-screamer-black-version-2.html
« Last Edit: October 27, 2012, 07:01:09 AM by jrhorton »
VRCC #6897, Joined May, 2000
1999 Standard 2007 Rocket 3 2005 VTX 1300S
« Reply #19 on: October 27, 2012, 10:02:33 AM » |
Yes you do need a relay, I found that out when I fried my horn button with a long blast. Hoser
mario
« Reply #20 on: October 27, 2012, 03:12:40 PM » |
 big bf quad
Mario 01 Valkyrie Standard (sold) 12 Suzuki V-Strom 1000
« Reply #21 on: October 27, 2012, 06:35:06 PM » |
They say a picture is worth a thousand words, here's 2K for you.
Chattanooga Mark
« Reply #22 on: October 27, 2012, 08:14:47 PM » |
Another vote for the BigBF Quad setup. Really glad I have them on my Interstate.
All the best,
Mark
...do justice, love kindness, walk humbly... The Bible: Read, Apply, Repeat 2012 Victory Cross Country Tour, in all its pearl white beauty www.bikersforchrist.org
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #23 on: October 28, 2012, 04:13:14 AM » |
They say a picture is worth a thousand words, here's 2K for you.   I've heard this horn recently on the FCR and it rocks ANYTHING out there. Really cool AND effective.
« Reply #24 on: October 28, 2012, 09:14:19 AM » |
They say a picture is worth a thousand words, here's 2K for you.   Those are big skinhead......but these.....oh my gosh.......this might get the attention of little miss texting while driving....ya think!?!
« Reply #25 on: October 28, 2012, 09:19:43 AM » |
They can never be 2 big or 2 loud!
ryord
« Reply #27 on: October 28, 2012, 04:26:05 PM » |
Thanks to all, as always the responses are illuminating.
