February 06, 2026, 12:48:44 AM *
Author Topic: Rear shocks?  (Read 1903 times)
Chiefy
Sarasota, Florida
« on: October 28, 2012, 08:18:10 PM »
My bike rides nice either by myself or two up.  However, 2 up, the mufflers drag a little in corners.  They touch well before the pegs.  The shocks don't bottom out, and they're not bouncy.  I have a 98 standard with what appears to be the stock shocks, at 58,000 miles.  They are preset at 5. The mufflers are the 2BR 6 into 2, nothing wrong with how they're mounted.  I assume I should replace the shocks with progressives.  But is there anything else to check before I spend the $$ ?   Also, any recommendations for replacements, sort of a "good/better/best"  thing?
Thanks.
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: October 28, 2012, 08:45:53 PM »
My TBR's would be the first thing to grind, especially two up. The pipes just jut out more than stock.  Both pipes had nice rashed edges.  I went to Works performance shocks and they no longer grounded out.  Really messed up my lean angles.
I went to stock pipes and got a little more lean again.
You could always check your shock bushing, both upper and lower, and  ensure that they haven't wallowed out.  There are aftermarket bushings that are much better than OEM.
I like the Works shocks, as they are built for your riding weight, and are rebuildable.
Ride safe.
« Last Edit: October 29, 2012, 04:43:25 AM by chrise2469 » Logged
« Reply #2 on: October 28, 2012, 10:45:11 PM »
I too have Works shocks. Good quality but pricey. Progressive 440HD in a 13 inch length would be best for 2 up riding.
john
tyler texas
« Reply #3 on: October 29, 2012, 11:46:09 AM »
if you can find shocks off of an instate you might give them a try ...             cooldude
they are bigger around (heavy duty) than the ones on your standard ...
vrcc # 19002
« Reply #4 on: October 29, 2012, 12:11:52 PM »
knuckle buster posted a set of I/S shocks for sale 27 Oct 2012 for $50.00 buyer pays shipping. In the board classifieds. Hope this helps you some. RIDE SAFE.
« Reply #5 on: October 29, 2012, 02:23:29 PM »
I love my I/S shocks on my Tourer.
JaysGone
Delray Beach Florida
« Reply #6 on: October 29, 2012, 03:17:20 PM »
From my limited experience.
Id say your shocks are shot.
My bike came with 440s and the HD springs 13 inch from a PO.
Took them off after a few weeks to stiff for me.
I git a set of regular OEM shocks and at #3 were too stiff at less they bottomed out.
I now have IS shocks on it set on 1.
I wish they had a .05 setting.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
Chiefy
Sarasota, Florida
« Reply #7 on: October 31, 2012, 04:52:39 PM »
Thanks for the input.  Maybe I'll chase down some IS shocks, and see if I can tweak the muffler hangars up a little.
