February 06, 2026, 12:48:42 AM *
Author Topic: ramifications of 'desmog'?  (Read 2846 times)
Valkyr01
Homer Glen, IL
« on: October 31, 2012, 07:42:52 PM »
First, I really appreciate all the good information on this board. It's helping me get through a carb rebuild.
As long as I have the carb assembly removed, I've been considering the 'desmog' procedure. Besides removing the PAIR and related reeds/hoses/pipes, what adjustments may need to be made to carbs, if any? How is engine performance affected (rougher, higher/lower idle, etc)?
And you've convinced me that the fuel flow control from the stock petcock can be improved upon, so I'm going to install a Dan-marc electric shut-off valve. I'm working on the carbs because #2 cylinder is filling with fuel (hydrolock). #6 was too, but seems to have unstuck. So, even though I've already installed a new petcock, I'd rather overbuild. And it's going to get an in-line filter, too. This is what I get for leaving the valve in 'on' position for 2 months without riding.
Anyone who's 'desmogged', please describe anything else you did to prevent problems.
Joe V.
2001 Valkyrie Standard (blue/white)
2000 Valkyrie Tourer (black)
Colin
My old job
Orba, Spain
« Reply #1 on: October 31, 2012, 10:38:02 PM »
Joe
Nothing. All I did after my desmog was a carb balance to make sure everything was in sync and that was it.
Colin
VRCC Espana
My Bumble Bee re-build
fordmano
San Jose, CA.
« Reply #2 on: November 01, 2012, 12:58:55 AM »
yep, Nothing at all unless you had a related problem prior to desmog..
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Chiefy
Sarasota, Florida
« Reply #3 on: November 01, 2012, 03:40:09 AM »
Joe V.
Engine performance after a desmog is unaffected.  Unless you had a vac leak that the desmog fixes.  I didn't have to do anythong to the carbs after I desmogged.
A Danmarc with a stock petcock still leaves one route to hydrolock.  Via the vac line from the petcock to carb 6.  How likely that is to happen. I don't know.  But I guess the Danmarc seals off 6 other routes.
« Reply #4 on: November 01, 2012, 03:48:24 AM »
I'd suggest looking in shop talk or the archives for Normands [Quexpress] article on de-smog.. Its the best one written.. I's also suggest trashing the original petcock and installing a Pingle..
« Reply #5 on: November 01, 2012, 04:24:36 AM »
cooldude on the Quexpress article being complete. Now that I have desmogged mine, and helped
to replace all the vacuum lines on Stanley Steamer's bike, I kind of wish I'd left all that original
stuff on mine. Other than removing a bunch of stuff, desmogg is a no-op...
I like the OEM petcock  coolsmiley I can't relate to removing a bunch of OEM tubes and valves and
replacing them with a bunch of other tubes and valves...  crazy2
Red Diamond
Beaumont, Texas
« Reply #6 on: November 01, 2012, 12:57:20 PM »
Well said, waste of time and money.
Dozer
Humble, Tx
« Reply #7 on: November 01, 2012, 02:23:25 PM »
I did nothing. After the carb rebuild and syncing I rode it 800 miles since then and no issues at all except for losing a source for vacuum leaks and cleaning up the general appearence under the carb bank.
I used Dead Eyes shiney desmog kit. Mileage is very slightly improved but thats probably due to the carbs. So far, its all good.
Valkyr01
Homer Glen, IL
« Reply #8 on: November 01, 2012, 05:25:50 PM »
Thanks to all for their input.
Conclusions - 1) desmog process doesn't affect drivability
2) questionable benefits - doesn't improve anything, (but probably pollutes more?), maybe better gas mileage?
3) less parts to worry about (i.e. vaccuum lines, etc)
Joe V.
Dozer
Humble, Tx
« Reply #9 on: November 02, 2012, 12:30:53 PM »
Thats correct but I believe someone here said that the Valk would pass todays emission test even before the smog kit was required. So as for more pollution, its doubtful but I couldnt say for certain.
Besides that, with the age of the bike, whatever the EPA does would probably have the Valk grandfathered into some older pollution clause anyway...IMHO
sugerbear
wentzville mo
« Reply #10 on: November 02, 2012, 03:14:49 PM »
i believe the answer is " the solution to pollution is dilution"
our smog systems just pumped more air into the exhaust, lowering the ppm.
not the total amount put out. that would require a catalytic converter.
