August 12, 2025, 12:15:30 PM
Size of oil drain plug? And a supplier?
Topic: Size of oil drain plug? And a supplier? (Read 2258 times)
lljjmm
November 04, 2012, 05:42:32 PM »
What is the size of the oil drain plug?
Want to replace with a magnetic one,
There are magnetic plugs out there that have more magnetism than others. Does any one know of a really good one and the supplier.
Thanks in advance
John U.
Southern Delaware
Re: Size of oil drain plug? And a supplier?
November 04, 2012, 06:10:03 PM »
Check out Valkyrie Bling. I have a couple of his magnetic drain plugs, strong magnets. Mike is a good guy to deal with as well.
http://www.valkyrieblingandmore.com/magnetic-drain-plug11.html
Warlock
Magnolia, Ms
November 04, 2012, 06:30:57 PM »
Quote from: lljjmm on November 04, 2012, 05:42:32 PM
Thanks in advance
Here's a good place. I've 2 sets for my wife's Can Am spyder here
http://www.magneticdrainplug.com/motorcycle.html
David
November 04, 2012, 08:18:21 PM »
The drive unit is the same size and has a magnet. Just get an OEM plug for the rear drive.
November 04, 2012, 09:47:02 PM »
Quote from: sandy on November 04, 2012, 08:18:21 PM
Aw come on Sandy, that would be too easy.
LOL
9Ball
November 05, 2012, 04:30:49 AM »
Thanks in advance
14mm (if you didn't get the answer)
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Reply #6 on:
November 05, 2012, 04:53:18 AM »
You might want to combine your magnetic plug with this;
http://www.motionpro.com/motorcycle/articles/view/633/motion_pro_oil_filter_magnets/
My rides:
Reply #7 on:
November 05, 2012, 06:17:03 AM »
I have also seen magnets that wrap around the oil filter to hold metal particles inside the filter.
GOOSE
D.S. #: 1643
Southwest Virginia
Reply #8 on:
November 05, 2012, 02:23:17 PM »
GO LOOK UP THE NUMBER OF THE DRAIN PLUG FOR THE FINAL DRIVE.....THIS PLUG WILL SCREW RIGHT IN, AND REPLACE THE STOCK DRAIN PLUG. I PUT THESE ON MY VALKYRIES, AND A WING....THEY WORK. HONDA PART #: 90081-MC7-000 ....HDL PRICE: $ 6.10.
Last Edit: November 05, 2012, 02:30:38 PM by GOOSE
=> InZane XXV
