August 10, 2025, 05:48:33 AM
saddlebag mounting issue
Topic: saddlebag mounting issue (Read 992 times)
larue
Clermont,FL
November 10, 2012, 04:40:59 AM »
Can anyone tell me how to install the OEM saddlebag brackets the easiest way, i can never get those bolts to go back in place right away, i have to lift the fender till the holes line up, it pain the a$$$$, it took countless hours and another helping hand to put one side,but still working on left side, i just wanna a trick to be able to take them off anytime i want without worrying about the pain to put them back on. thank you in advance
Re: saddlebag mounting issue
November 10, 2012, 05:06:13 AM »
Put it on a jack, easier to align the bolts. you can slip a floor jack under the tire while it is up on the stands and move it up and down. Loosen the shock mounts too. It can be aggravating, I Know. Hoser
Last Edit: November 10, 2012, 05:09:05 AM by Hoser
tank_post142
south florida
November 10, 2012, 05:57:59 AM »
can I ask why you would be taking the bag mounts off and on enough to worry about this? one option would be to remove one bolt loosen the other swing the mount and put the bolt back in the open hole before removing the second bolt.
I got a rock
VRCCDS0246
mmurffy03
03 standard
toms river new jersey
November 10, 2012, 06:06:24 AM »
never take both bolts completly out at the same time is the way i do it
November 10, 2012, 06:08:59 AM »
The (discontinued) Rattlebars kit makes it a breeze. It would be easy to make your
own...
http://www.valkyrieforum.com/bbs/index.php?topic=865.0
... I bet someone's
got some pictures somewhere...
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
November 10, 2012, 06:43:47 AM »
I just put Easybrackets on mine. Quick on and off with a key. Takes a few seconds.
Here's a pic of the Easybracket before mounting the bags.
Patriot Guard Riders
mmurffy03
03 standard
Reply #6 on:
November 10, 2012, 12:27:26 PM »
see if this might work
http://www.metricthunder.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MT&Product_Code=3501-0334&Category_Code=SA20
longrider
Vernon, B.C. Canada
Reply #7 on:
November 10, 2012, 01:17:12 PM »
as mentioned above only remove one bolt at a time, I also taper the end 1/4 inch with a grinder
larue
Clermont,FL
Reply #8 on:
November 10, 2012, 02:00:42 PM »
thanks everyone for all your help, i got them on after couple frustrating hours, i dont think i will ever take them off again after what i just went through.
=> InZane XXV
