February 06, 2026, 02:19:28 AM
RP#62 Thank you
Topic: RP#62 Thank you (Read 1092 times)
Firefighter
Harlingen, Texas
RP#62 Thank you
November 12, 2012, 04:21:56 PM »
Thanks to all who advised me, especially RP#62, after I posted my electrical problems. Cleaned both ends of the battery ground wire, but still had voltage loss at factory fuses. Seems the engine and frame are not grounding well enough. After I ran a new ground wire from the battery ground to the frame, so far things are better. My gauges are more accurate and not floating around and with all acc. on I maintain 14.2 volts, and more than 13 volts at long idle. Time will tell but happy so far!!! Thanks to all. Firefighter 2000 IS
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Re: RP#62 Thank you
November 13, 2012, 07:53:05 AM »
The crimped on connectors at the ends of the battery cables are also included when discussing poor and corroded connections.
They are exposed to the elements and will definitely corrode within the connector.
RP#62
Gilbert, AZ
Re: RP#62 Thank you
November 13, 2012, 07:35:48 PM »
Glad to hear it ended up being something simple.
-RP
