April 02, 2026, 11:11:55 PM *
Author Topic: F6B or K1600GT?  (Read 7489 times)
Momz
ABATE, AMA, & MRF rep.
« on: November 14, 2012, 04:23:22 PM »
The closest competitor to the Honda. BMW claims 160hp and both priced similiarly priced. But the Honda looks better to me (JMHO).
ALWAYS QUESTION AUTHORITY!
YoungPUP
Valparaiso, In
« Reply #1 on: November 14, 2012, 04:27:28 PM »
Apples to oranges.  K1600Gt in the ring with St1300 ok, but not a fair fight with the F6B.  F6B is a different kind of monster, just like the Valk.
99 STD (Under construction)
« Reply #2 on: November 14, 2012, 04:52:52 PM »
I like the Beemer just don't never see me buying one beside it's butt ugly in the rear  Undecided
I've got this heavy on my mind but I own ( 3 ) Valkyrie's that's PAID for ....Who knows I may go for it I like it much better than the Goldwing  Undecided   This is the closest thing to the Fat Girl thats came from Honda since 2003.
NITRO
Eau Claire, WI
« Reply #3 on: November 14, 2012, 05:22:12 PM »
I agree, you're comparing a bagger and a sport tourer. In a comparison like that, it depends what you're using the cycle to do.
When in doubt, ride.
« Reply #4 on: November 14, 2012, 05:25:10 PM »
f6b. Not sure what kinda chics your gonna pick up with the beemer.  2funny
FLAVALK
Winter Springs, Florida
« Reply #5 on: November 14, 2012, 05:36:12 PM »
...and if you do, chances are shes sporting store-bought teeth  Roll Eyes
« Last Edit: November 14, 2012, 05:41:59 PM by FLAVALK » Logged
« Reply #6 on: November 14, 2012, 05:39:45 PM »
...and if you do, chances are shes wearing store-bought teeth  Roll Eyes
   Or support hose.  2funny crazy2 cooldude RIDE SAFE.
« Reply #7 on: November 14, 2012, 05:51:17 PM »
The GTL is a totally different kind of machine and technologically way ahead of the F6B. Weight difference is also significant, the F6B is a porker. Now if Honda would wake up, maybe the F6B could be competitive. I'll stay with my Valks.
« Last Edit: November 14, 2012, 05:57:13 PM by salty1 » Logged
My rides:
flcjr
Manhattan,Montana
« Reply #8 on: November 14, 2012, 07:57:05 PM »
I like them both but why did Honda drop the cruise and reverse??? Those are the two most apealling things about it. tickedoff :tickedoff:I think when right deal comes around on a 1800 wing I will pull the trigger.
« Reply #9 on: November 14, 2012, 08:36:56 PM »
My local service shop sent me a link to the F6B and compared it to an HD Streetglide, not the Beemer. Different strokes I guess.
johnhunter44
Easley, SC
« Reply #10 on: November 15, 2012, 04:31:48 AM »
I'm with Salty on this.  The Beemer is 160 HP and will take off like a rocket.  Plus, its lighter than the Honda.  The technology is very high on the BMW.  The GTL has the coolest GPS I have seen and the controls for music are excellent.  I love both Honda's (some) and BMWs.  What chics can you pick up?  You pull up on the Beemer and on a Goldwing and see who gets the classiest chic on the back.  Loved my Valk, now I love my Beemer.....
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #11 on: November 15, 2012, 05:49:47 AM »
Not really comparable machines IMO. I love the beemer and would have one if I could. Also love the look of the Honda. What did they really do though. Shorten the windshield, lose the trunk, different seat, paint some things black. Is the motor the same as far as induction system and exhaust note? Pretty sure the insides are the same. I love the look except from the back, that view is absolutely awful. Like the Beemer though, I'd own one if I could, it's just I am more than a little worried about my finances since last Tuesday.
« Reply #12 on: November 15, 2012, 06:08:01 AM »
If your'e asking which of the two I would rather own, it would be the Honda.  A moot question though, I can't afford either one.  Oh well,I still have a Valkyrie!  Hoser   cooldude
« Reply #13 on: November 15, 2012, 07:05:53 AM »
2012 BMW K 1600 GTL | Motorcycle Specs
Engine: 1649cc, 6-cylinders, 4 valves per cylinder
Bore/stroke: 72/67.5mm
Output: 118/160.5 kW/bhp
Torque: 175 Nm
Compression/fuel: 12.2:1 / premium unleaded (95 RON)
Carburetion: BMS-X
Headlamp: xenon low beam, halogen high beam
Clutch: multiplate wet clutch, hydraulically activated
Gearbox: constant-mesh 6-speed gearbox, helical-toothed
Frame construction: chill-cast, aluminum, extruded sections
Wheel control (front): wheel dual longitudinal control arm
Wheel control (rear): Paralever (single-sided swing arm), central spring strut, rebound/continuously variable
Brakes (front): two-rotor disc brake, Ø 320 mm, radial 4-piston fixed caliper
Brakes (rear): single-disc brake Ø 320 mm, 2-piston fixed caliper
BMW Motorrad ABS (partial integral)
Wheels: aluminum: cast wheels - front 3.50 x 17", rear 6.00 x 17"
Tires: front - 120/70 ZR 17, rear 190/55 ZR 17
Total length: 2489mm
Seat height (without rider): 750-830mm
Unladen weight, incl. 90% fuel: 319kg (without pannier), 348kg (incl. pannier, topcase)
Permitted total weight: 560kg
Fuel tank capacity: 26.5 liters
2013 Honda Gold Wing F6B GL1800B/GL1800BD Specs:
Engine Type: 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke: 74mm x 71mm
Compression ratio: 9.8:1
Valve Train: SOHC; two valves per cylinder
Induction: PGM-FI
Ignition: Computer-controlled digital with 3-D mapping
Transmission: Five-speed including Overdrive
Final Drive: Shaft
Suspension Front: 45mm cartridge fork with anti-dive system; 4.8 inches travel
Rear: Pro Arm single-side swingarm with Pro-Link single shock with remote-controlled spring preload adjustment; 4.1 inches travel
Brakes Front: Dual full-floating 296mm discs with CBS three-piston calipers
Rear: Single ventilated 316mm disc with CBS three-piston caliper
Tires Front: 130/70R-18
Rear: 180/60R-16
Wheelbase: 66.5 inches
Rake (Caster angle): 29.15°
Trail: 109mm (4.3 inches)
Seat Height: 29.1 inches
Fuel Capacity: 6.7 gallons
Estimated Fuel Economy: TBD
Colors: Black, Red
Curb weight: 842 lbs
My rides:
cutter
Plantersville, Texas
« Reply #14 on: November 15, 2012, 07:29:47 AM »
I'm with Joe on this one. I am seriously contemplating adding the F6B.  uglystupid2 Why not.
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #15 on: November 15, 2012, 10:23:37 AM »
As far as the chick magnet thing, no brag here but I could pick up chicks on a vespa.
« Reply #16 on: November 15, 2012, 11:19:14 AM »
You and I are like twins, Romeo.
I had a co-worker who commented he was getting a motorcycle to improve his dating opportunities.  I sort of laughed it off, but less than eighteen months later he had gone from no dates; no relationships to happily married.
I guess it does work out for some and I guess some really do need it.
He bought a Davidson.
Jess Tolbirt
White Bluff, Tn.
« Reply #17 on: November 15, 2012, 11:24:15 AM »
whats the hp and torque of the honda?  cant compare without those,,,
Valkyrie member # 23084
« Reply #18 on: November 15, 2012, 12:48:46 PM »
Jess, it's going to be the same as a GW. Aprox. 118 bhp and 125 ft lbs.
« Last Edit: November 15, 2012, 12:55:23 PM by salty1 » Logged
My rides:
Elvis
« Reply #19 on: November 15, 2012, 02:19:24 PM »
Odd that you asked this question as I sat on a GT down in Florida last week,  I liked it but I want to see an F6B, not sure either will provide the comfort or torque of my current ride.
2008 Rocket 3 Touring
Dr Bobs Patient
Okatie, SC
« Reply #20 on: November 15, 2012, 02:46:37 PM »
If money wasn't an issue, I would look seriously at this Beemer.  I've test road an RT and a K series bikes a few ago, but the cost was prohibitive.  BMW dealers do not need to drop price to sell bikes.  They are real sweet rides IMO.
DBP
I keep doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
FloridaValkRyder
Apopka, Florida
« Reply #21 on: November 15, 2012, 02:55:02 PM »
Objectively speaking, since I'm not going to buy either one of them, I hate that Bat Mobile styling of the BMW. I know how great it is..blah, blah, blah. My I/S is all I want it to be. I have had 2 GW's, loved them. The F6B, without reverse, is no improvement over my bike. I do miss reverse though. But even when I did have them I wanted a Valk, now I do, I love it, I will keep it until I no longer ride.  cooldude
I still miss her.
bscrive
Ottawa, Ontario
« Reply #22 on: November 15, 2012, 06:05:51 PM »
I have ridden the 1800's and you will cook on them when the fans kick on.  My choice hands down would be the BMW.
