February 06, 2026, 02:24:56 AM *
Author Topic: Trigger wheel replacement question  (Read 1407 times)
Tx Bohemian
Victoria, Tx
« on: November 20, 2012, 01:23:06 PM »
Is there anything I should be aware of when changing the trigger wheel?
I looked through a Clymer manual and it looks like a "cut and dry" timing belt/chain replacement.
Any idiosyncrasies of these bikes I need to watch for?
Al
Joe Hummer
Arnold, MO
« Reply #1 on: November 20, 2012, 01:31:18 PM »
The biggest thing is to make sure the bike is at TDC and your timing marks are lined up.  You will want it this way when you put it back together.  Being off a notch or two won't bend valves but much more than that can.  You REALLY don't want to bend valves.
I also recommend using an impact wrench to remove the center bolt.  You will probably need to remove the front wheel and fender to do this...but it really is the best way...the tool found in the below site is used on the valve wheel and your belt can slip while using it...been there...done that...Its ok as long as you line up your marks again.
http://www.valkyrieriders.com/shoptalk/timingwheel.htm
Other than that...it is an easy swap.  Folks recommend running at least mid grade on the trigger wheel upgrade.  I have been running regular since I have done it and have a little knock when on it hard...but otherwise no issues.  Mileage has gone up a little...was getting 180-185 miles before reserve...now getting 190-195.  I have noticed an increase in power but no stats as it is seat pants dyno results.
Hope this helps.
1999 Valkyrie Interstate
tank_post142
south florida
« Reply #2 on: November 20, 2012, 02:29:54 PM »
just ask Sgt. Joe !
http://www.valkyrieriders.com/shoptalk/joeswheel.htm
I got a rock Sad
VRCCDS0246
« Reply #3 on: November 20, 2012, 02:34:54 PM »
It is an easy straight-forward job.. But like Joe said,, double check your work and don't let a pulley move/slip..
Thunderbolt
Worthington Springs FL.
« Reply #4 on: November 20, 2012, 04:48:02 PM »
It was many moons ago that I changed the one on my Tourer, but the main pitfall is if the marks all do not line up when you are finished.  Use some sort of marking to show where the belt was on the pulley, I used white-out, so that you can re-align it when you put it back together.  Spring tension on the valves will probably attempt to move the wheel.  Be VERY sure that every thing is lined back up..........did I already say that?  Not to alarm you, but some have bent valves after doing this because they weren't paying attention.
