« on: November 22, 2012, 08:31:46 AM » |
It was bought in 2004
Bike starts on 1st tap of the starter. I ride year round bike never sits more than a few weeks during winter
But thinking about just getting the new maintenance free from directline at 57 during the sale
I understand I must charge it before installing. Will it keep uncharged for another year if my present battery keeps chugging along or must I charge it right away and put a tender jr on it every once in a while
I had it load tested a few years back and it tested around 80% but has never failed to start 1st press of the button
« Last Edit: November 22, 2012, 08:33:56 AM by Oss »
saddlesore
« Reply #1 on: November 22, 2012, 08:37:05 AM » |
I have a 99 standard. I always used a battery tender and I replaced it last year. !2 years old, not bad. Problem is you keep waiting for it to fail a the most inconvenient time.
DARE TO BE DIFFERENT
olddog1946
« Reply #2 on: November 22, 2012, 08:39:36 AM » |
That's a good question. No one ever buys a battery until their's is shot, lol. But if you think about it, batteries sit on the shelf for extended periods of time, so having it at home til you need it, then putting in the electrolyte, charging and using when you need it shouldn't be a problem.
I should mention that having a new battery at home means your's will go belly up somewhere around Wyoming.
« Last Edit: November 22, 2012, 08:42:01 AM by olddog1946 »
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
« Reply #3 on: November 22, 2012, 08:43:39 AM » |
I have mixed emotions about battery tenders.
If the battery tender have an absolutely correct float charge maintainer I think, that's good and the battery should last pretty much,,, forever.
However if the float charge maintenance is not at the proper voltage level, then damage to the battery is inevitable.
I have two tenders, neither of which is the same and my doubts about the ability of either to correctly maintain a battery is high.
The oldest, a Sears (tapering model), one time did finish off an old battery which came as a big surprise to me.
The newer one, which came from WalMart, I'm not convinced yet but have no definitive opinion. I've got it hooked to my riding mower. Probably will know better in the spring.
Regardless,,, to answer your question, I think it's best to fully complete the charging cycle according to the manufacturer's instruction,,,,prior to putting it on the tender.
Others may have different opinions.
« Reply #4 on: November 22, 2012, 08:49:22 AM » |
If I were in your position, I would fully charge and install the new battery and use the old battery for bench-testing electrical components.
Moonshot_1
« Reply #5 on: November 22, 2012, 08:53:08 AM » |
I don't know how old the battery in my bike is. I'm sure there is some kind of marking on it. Had 17k when I got it. Likely the original battery. Bought the bike used (99 tourer) 6 years ago. So I know it's at least 6 years old. 76k miles now, bikes been down once (hit by tractor on hwy while trying to pass it) so it's been tossed about, I killed the battery dead dead dead no less than 4 times and once dead dead dead dead (switch on for hours, not even a click). Don't use a battery tender either. I would say that, unless I leave the switch on for hours, it starts first time every time but that would be just jinxing it, so I'll not say that at all. In fact, never mind this post at all.
« Last Edit: November 22, 2012, 08:55:32 AM by Moonshot_1 »
Mike Luken
Cherokee, Ia. Former Iowa Patriot Guard Ride Captain
bentwrench
« Reply #6 on: November 22, 2012, 09:04:45 AM » |
Be careful with old batteries,they can short out and over work your alt. I've seen cars and bikes with low or no charging voltage perk right back up when the shorted batt. was replaced.keeping a batt. more than 5-6 yrs. may not be good idea. bw
« Reply #7 on: November 22, 2012, 09:08:13 AM » |
OSS: If you don't currently own a charger, get a CTEK 3300 from Amazon. Much better quality than BT jr. www.CETEK.com
« Reply #8 on: November 22, 2012, 09:15:39 AM » |
I would also look for an alternator source for all youse that keep batteries over 10 years. Chances are it will fail at the worst possible time (and it will fail), and your alternator is going to pay a price too keeping an old battery alive past its life expectancey.
« Reply #9 on: November 22, 2012, 09:21:08 AM » |
Thanks everyone
I ordered the battery and a replacement for my battleaxe 200/60/16 tire which that tire was 143 I think with free shipping
Happy Thanksgiving all of you.
Sandy I do have the tender jr and also the bmw charger
F6Dave
« Reply #10 on: November 22, 2012, 10:04:43 AM » |
I got 9 years out of one Valk battery!
« Reply #11 on: November 22, 2012, 10:13:37 AM » |
Took mine out after 10 years and changed it for peace of mind on the long Texas ride a few years ago....That battery is now in my 4 wheeler and starts everytime.
« Reply #12 on: November 22, 2012, 10:52:07 AM » |
Brother Oss-i just recently went thru the battery/altenator switch out and curse the people deal. My battery was starting first time every time. When the battery went south it took the alt with it. The alt can be changed on the side of the road-but i'd much rather do it in my shop. And when it goes out-and it will-it won't give a flyin hoot where yer headed and who you is and where it quits.  Well it will wait to go out when yer between lost and found and B.F. Eygpt.  RIDE SAFE.
« Reply #13 on: November 22, 2012, 11:10:56 AM » |
Mine started just fine one morning. 30 miles later, nothing. Got jumped and made it home. It went fast. I change mine every 5 yrs, reguardless.
« Reply #14 on: November 22, 2012, 01:06:18 PM » |
I agree with Rickey, my first lasted seven years without battery tender, second 2 years with. The third is still in the bike without. (3 yrs so far) Hoser
« Reply #15 on: November 22, 2012, 01:30:09 PM » |
No tender ever. Never any on the lawn mowers or tractors. They all fire up.
signart
« Reply #16 on: November 22, 2012, 02:12:01 PM » |
I bought my '98 standard in '03. Changed the battery last year (2011) Had a build date on battery '07. I assumed it had a new battery when I puchased it. Never saw a battery of any kind last that long.
2003Valkyrie
« Reply #17 on: November 22, 2012, 05:19:46 PM » |
2003 Valkyrie Standard-------42,000 miles !!!!!!!! Same battery from day one.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #18 on: November 22, 2012, 05:35:16 PM » |
I had a battery go 10 years. It was the original and I never pulled or charged it over the Ohio winters.
 ************************************************************** Dropbox is a neat app I found that I use to store files and pictures of my Valk. **
« Reply #19 on: November 23, 2012, 04:59:31 AM » |
I got a new alternator at 90,000 miles, figuring I would need it sooner or later, at 110,000, It's still in the box.  Hoser
maniscar
VRCC #2225
Southern NH
« Reply #20 on: November 23, 2012, 07:34:38 AM » |
Mine battery is original from '03. Still starts the bike but, just recently it's taking longer. Bike stalls too and have restart a couple of times and hold the throttle for a few seconds. I have a new one I bought from DirectLine 2 years ago but never even opened the box. I think I'll prep the new one this weekend. Good point about the alternator. Never thought about that!  Rich
« Reply #21 on: November 23, 2012, 10:03:09 AM » |
I did exactly the same thing, my original 99 Valkyrie battery is now on my 2003 Honda Rincon.
signart
« Reply #22 on: November 23, 2012, 12:22:24 PM » |
There is a difference between a battery tender and a trickle charger. A good quality b/t will maintain the charge to proper voltage without overcharging, as my 14 yr. old oem battery removed from my '98 in 2011 will testify. Even with that it still amazes me. Anytime you let a battery discharge below the voltage the battery was designed, for a period of time, you have damaged the battery. It will never recover the optimum charge it had previously. Each time this happens the recovery will be less and less. Even a fully charged battery in good condition, sitting idle for 2 weeks should get a charge for max life.
SPOFF
« Reply #23 on: November 26, 2012, 04:39:34 AM » |
Replaced the OEM battery on my 1997 after 12 years. I would leave it in the bike all winter (6 months, as low as minus 30) and it would start right up in May. I finally replaced it because it was old.
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #24 on: November 26, 2012, 07:57:31 AM » |
I change my battery every 5 years (will buy the third one in spring)... Not worth putting the alternator through the extra work of charging an old battery. As to chargers/tenders/minders, I have used BatteryMINDer (Charger/Maintainer/Desulfator) from Northern Tool, for years. Each unit can maintain up to 4 batteries, and are currently on sale for under $30. I use one to maintain the Valk, and the start and trolling batteries for my boat. I use the other to maintain the 4 Wheelers batteries, along with my garden tractor battery. More info here - http://www.northerntool.com/shop/tools/product_200332201_200332201Black Dog
Just when the highway straightened out for a mile And I was thinkin' I'd just cruise for a while A fork in the road brought a new episode Don't you know... Conform, go crazy, or ride a motorcycle...
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #25 on: November 26, 2012, 03:41:28 PM » |
The stock battery was still in my bike when I bought it. It last over 8 years. The replacement last only 5 years. Now back to OEM, 3 batteries in a 14 year old bike.
Jack B
« Reply #26 on: November 26, 2012, 03:44:28 PM » |
My OEM battery from my 98 Tourer isin my lawn tractor with a snow blower on it. Hope it makes it though this winter.
Let’s RIDE
DarkSideR
Pueblo, Colorado
« Reply #27 on: November 27, 2012, 02:08:14 PM » |
I inherited my 2001 Valk from my father who was the original owner. He swears it still has the original battery in it. Bike has 37k. Battery is tended in the winter (in Colorado).
After reading this post, I am now wondering if I have the oldest batter around.
Think I going to pull a Thelma & Louise and see how far I can go...
2001 Valkyrie Super Tourer VRCC#34410 VRCCDS#0263
