November 26, 2025, 07:19:53 PM *
Author Topic: Carb cleaner-how's it work?  (Read 1990 times)
« on: November 22, 2012, 11:17:14 AM »
In the past I have used Gumout Regain as a carb cleaner. Used it going west this yr. Regain is suppose to increase MPG. And it does. I normally get 32 mpg. Used regain and get 38 mpg. Its constant for the 1st 300 miles or so then it slowly drops back to 32 mpg after 5-600 miles. So how does it work? And why dont it stay at 38 mpg? Something I wondered for awhile.  uglystupid2
« Reply #1 on: November 22, 2012, 04:20:38 PM »
I would think it has more to do with speed, vehicle weight, and wind direction vs. direction of travel.  I find it hard to believe that any additive you put in the tank would have that kind of impact on fuel economy.  If you really want to verify this.
get 1 gallon of fuel with no additive and 1gallon of fuel + additive (1 gallon total)
Drain your tank, add a gallon of either fuel and drive at a constant speed until you run out of fuel (preferably in kansas on a flat straight road)record distance traveled. Add the other gallon of fuel and continue to drive until you run out,  record and compare distance traveled.
I bet you wopn't see much difference.
Most carb cleaners are just solvents that dissolve deposits.
« Reply #2 on: November 22, 2012, 05:49:55 PM »
It only works with the Regain. No other cleaner. Did it last yr to the Ind Ride with kit and luggage. 38 mpg. Did it again going to Sturgis. 1 up fully loaded. From home to Iowa was 38 mpg. Then each stop it slowly returned to normal by the time I got to Sturgis. 75-80 mph and filling up at 125 ish miles.
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #3 on: November 22, 2012, 06:08:34 PM »
 I get 25-30 mpg.....only way I'm ever gonna get any better is if I break my wrist....Smiley
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
JaysGone
Delray Beach Florida
« Reply #4 on: November 22, 2012, 09:15:19 PM »
Ive had a similar experience when using Techron a full bottle to 5 gallons of gas in any bike.
Or in my Z 28 a bottle for every 20 gallons of fuel.
In the car on the higway.
Mileage will increase from its normal 21 mpg to almost 28 for the same speed and distance.
I believe that the additives make the gasoline burn more effectively.
Chevron adds techron at the pump but in much smaller per gallon amounts.
As a mileage booster both products do work and work well.
But it is NOT cost effective per gallon to achieve it.
Its cost per gallon simply doesnt justify its use every tankfull.
Of course your not going to get the mileage benifit once its been consumed.
But you will have a cleaner bunch of carbs which in itself should increase your mileage a bit.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
olddog1946
Moses Lake, Wa
« Reply #5 on: November 27, 2012, 09:46:11 AM »
10-4  cooldude cooldude cooldude
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #6 on: December 01, 2012, 07:39:38 AM »
No its been at diff temps. Aug temps and sept/oct temps. Filling is about the same. There is also no diference at speeds. 75-80 in Aug and 65 ish in the fall.
Yea, let me know what ya thing about it.
