November 25, 2025, 03:05:02 PM *
Author Topic: Is this what hitting the rev limiter is like?  (Read 2434 times)
rayvin57
SW Florida
« on: November 26, 2012, 09:11:13 AM »
On the way home from a nice long ride with the wife.  Accelerated hard from a stop light, took the revs pretty high in 1-3rd gears, don't think I came anywhere near redline (but wasn't watching the tach), was doing the same in 4th when I heard a muffled 'whap' sound coming from what I thought was the front of the engine, accompanied by a complete loss of power.  Thought I broke a belt so I immediately pulled in the clutch and coasted to a grassy area on the side of the highway.  Shut it off.  Thoughts of having to be towed and hopes that I didn't trash the heads ran through my mind.  I decided to try turning the engine over and it started up like nothing had happened.  Cautiously eased into first and rode away.  The fat girl ran as normal all the way home.
Anyone think I just hit the rev limiter in 4th?  Is the noise I described what happens?  Any help would be appreciated.
« Reply #1 on: November 26, 2012, 09:21:10 AM »
That sound nothing like when mine hits the rev limiter.......it just starts burbling like its starving hard for gas, and there is a noticable drop in power.  Would not call anything a "whap" sound
PS...I dont think I ever hit the rev limiter in 4th gear......only in 1st or 2nd so maybe its different at higher speeds.  If all is fine now, I would assume as you are asking as well, it was just the rev limiter
« Last Edit: November 26, 2012, 09:31:00 AM by Chrisj CMA » Logged
olddog1946
Moses Lake, Wa
« Reply #2 on: November 26, 2012, 09:31:40 AM »
Mine just spits and sputters, loosing power when I get the rpm up there.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #3 on: November 26, 2012, 10:21:56 AM »
When I used to hit the rev limiter in higher gears it was just a burbling sound, back off the throttle a hair and shift to a higher gear always helped and it ran like a tiger with creosote on its hind end.
rayvin57
SW Florida
« Reply #4 on: November 26, 2012, 11:07:02 AM »
Ok, that leaves the rev limiter out--this was a definite 'whap, snap' sound, but muffled, like it was a belt snapping behind the cover.  Then the power was just gone.  Maybe it just popped out of gear.  Maybe I ran over a palm frond that I missed seeing--but that wouldn't explain the sudden power loss, plus I would've heard a second sound as the rear ran over it. Maybe a palm frond plus popping out of gear at exactly the same time...
quexpress
Montreal, Québec, Canada
« Reply #5 on: November 26, 2012, 11:15:10 AM »
I once hit the rev limiter (in first gear) on my Valk while "playing" with another Valk at Americade. The engine cut out abruptly. After shutting it off, it started no problem.
I still have a full deck.
I just shuffle slower ...
rayvin57
SW Florida
« Reply #6 on: November 26, 2012, 11:20:08 AM »
But no muffled 'whap' sound like I had, I'm assuming.
« Reply #7 on: November 26, 2012, 11:31:47 AM »
Nice avatar Normand..
« Reply #8 on: November 26, 2012, 03:33:25 PM »
Mine does what ChrisJ described. It's like it has a complete loss of fuel. Back off and it runs fine.   laugh
My rides:
rayvin57
SW Florida
« Reply #9 on: November 26, 2012, 04:25:18 PM »
Sounds like you didn't shift hard enough and it popped out of gear and then hit the limiter.
I think I like your explanation the best, Mase  cooldude...
NJF6Cowboy
« Reply #10 on: November 26, 2012, 04:47:37 PM »
I hear that "whap" sound almost every time I ride with my wife. I goose the throttle too hard and "whap" I get a big slap to the helmet.  Cheesy
rayvin57
SW Florida
« Reply #11 on: November 26, 2012, 04:49:26 PM »
2funny
YoungPUP
Valparaiso, In
« Reply #12 on: November 26, 2012, 05:08:16 PM »
Not trying to hijack by any means, but where does the rev limiter "step in" on the valk?
99 STD (Under construction)
Valker
Wahoo!!!!
Texas Panhandle
« Reply #13 on: November 26, 2012, 05:42:55 PM »
Mine is totally stock and kicks in at about 7300 RPM.
« Reply #14 on: November 26, 2012, 05:58:47 PM »
I think they set the upper limit at 7500 rpm, just about the time your hanging on for dear life.  2funny  Evil  Cheesy
« Last Edit: November 27, 2012, 11:40:15 AM by salty1 » Logged
My rides:
« Reply #15 on: November 27, 2012, 05:36:54 AM »
Power peak is at 6000 to 6500, shift fast or you'll hit the limiter.  Hoser
rayvin57
SW Florida
« Reply #16 on: November 27, 2012, 05:48:45 AM »
Is your bike stock, Hoser?
Buda
Buda IL
« Reply #17 on: November 27, 2012, 05:01:55 PM »
7250.
At WOT just keep the throttle at WOT and when it hits the limiter is when to shift.  Chet has a write up about it I think.  It take s a little practice but when you find the sweet spot the shifts come easy.
Where might I find this?
97 Valkyrie
33344
quexpress
« Reply #18 on: November 28, 2012, 02:35:57 PM »
It's just an "image" of my current situation Pat!
I'm quite sure that I have lots of company LOL!  coolsmiley
« Reply #19 on: November 28, 2012, 05:11:14 PM »
All but cut piggies and drilled rear baffles and truck stacks and grumpy's exhaust tips.
