November 26, 2025, 07:21:24 PM
Wiring power amp to stock I/S AM/FM radio
Topic: Wiring power amp to stock I/S AM/FM radio (Read 1048 times)
rocker333
November 26, 2012, 02:08:41 PM »
I've seen this question asked and lots of pictures but I've yet to see a clear answer...
Is there a wiring diagram somewhere on how to wire an aftermarket power amp to the stock Interstate radio wiring???
Do I use the stock speaker wires for amplifier inputs???
thx guys...
Rio Wil
Re: Wiring power amp to stock I/S AM/FM radio
November 26, 2012, 11:00:53 PM »
If your aftermarket amp has a HI LEVEL input, you can just use the speaker wires as a input.....start with the volume on minimum.
PhredValk
Edmonton, Alberta, Canada
December 02, 2012, 11:06:34 PM »
Your power amp should come with instructions. Mine (Pyle waterproof marine amp) says to set the input switch to 'speaker' if using speaker wires or other hi power lines, like headphone wires for input and 'line' for line inputs.
My issue is with the rear speaker wires, which the Clymer guide shows in the wiring diagrams. I'll have to hunt for them, but I know they're there. Electrical Connections has a rear speaker wiring harness available with fader control.
Fred.
VRCCDS0237
=> InZane XXV
