February 06, 2026, 05:57:24 AM *
Author Topic: Media Blaster  (Read 1266 times)
« on: December 02, 2012, 04:25:55 PM »
Anyone here ever used a media blaster ? I've got a S-10 Kingcab that had a sorry paint job just before I bought it several years ago and it would be alot of work to sand the thick cracked paint off it. I'm thinking about renting a media blaster to do the job. Whats best sand or glass , plastic beads ? If you used one take a guess at how many lbs. of material I would need to do the entire truck and inside the bed ?
Grumpy
Tampa, Fl
« Reply #1 on: December 02, 2012, 05:05:52 PM »
Actually, the best media is either Walnut shells, or soda blasting, both will remove the paint with out damaging the metal. Sand blasting will leave the metal very rough, and will require sanding and filling primers to get the metal smooth again.  We used a lot of soda blasting at the air port, but it was a must there, don't need sand blowing around aircraft. The soda, could just be washed down with water, and it dissolves completely.
« Reply #2 on: December 02, 2012, 05:19:14 PM »
Thanks for the advice  cooldude
hal47
INDIANA
« Reply #3 on: December 02, 2012, 06:40:00 PM »
Joe I think air craft stripper and a high presure washer would be faster and cheaper,might check it out.
« Reply #4 on: December 02, 2012, 07:35:00 PM »
I'll look into that Hal ...Thanks for the suggestion  cooldude   It will be sometime into the new year before I do this with Christmas coming up and wanting to do several winter rides to the ocean the coins will be thin.
Joevalk
Santa Fe, Texas
« Reply #5 on: December 03, 2012, 04:04:56 PM »
Hey Joe it is not wise to blast the larger flat panels. This will warp the metal. Paint stripper might be your best bet.
VRCC#32720
1999 Grn/Silver Interstate
signart
Crossville, Tennessee
« Reply #6 on: December 03, 2012, 05:20:25 PM »
Lot of upsides & downsides to consider with each media choice.
Sand will take it down the cheapest & fastest, but good chance large panels will warp and all glass and chrome will have to be removed or protected. Not really that great unless your project is completely disassembled.
Soda will not harm glass, rubber, or chrome (metal) no masking needed, but special care to remove the residue and prep prior to primer. If all residue is not completely removed, the paint will not stick.
Again, unless project is disassembled, stripper is very messy. You can't buy the good stuff anymore just anywhere.
Walnut hulls don't go far, used mostly in a booth so you can recover and reuse.
I think I would just sand it down and prime one panel at a time, unless you have  a week to work solid. Maybe hit a few tough places lightly with the blaster, especially where filler is needed.
« Reply #7 on: December 03, 2012, 05:26:39 PM »
Not to steal the post, but---
Media Blaster
What I'd like to use on Bob Costas and NBC!
