February 06, 2026, 04:19:18 AM *
Author Topic: quick question about audiovox CC.  (Read 1817 times)
Mr.BubblesVRCCDS0008
« on: December 03, 2012, 04:03:49 PM »
 I lost my relay that puts CC to ground. Relay is used becuase of LEDs in system.  Any problem just putting purple wire to ground to test rest of system. I know it will no disengage with the brakes hooked up this way but I will still have off and clutch switch  to disengage CC. I just want to test the rest of the system as when relay went to ground alot of weird stuff happened.
Grumpy
Tampa, Fl
« Reply #1 on: December 03, 2012, 05:33:05 PM »
Just My 2 cents, change the relay, then try it. Might get your self into trouble real quick if you have to stop real quick. Trust me $5 for a relay is better than crashing.
« Reply #2 on: December 03, 2012, 07:06:03 PM »
It's not the cost. I'm having trouble finding the correct relay. I need a normally closed relay or  a SPDT relay to make this work. Radio shack near the house didn't have either. Oreilly's or autozone just have normally open relays to power lights or horns.
« Reply #3 on: December 03, 2012, 08:37:29 PM »
Check with an electrical supply house, there's a number of them in Houston.
Grumpy
Tampa, Fl
« Reply #4 on: December 03, 2012, 08:44:09 PM »
I picked mine up at Napa, has both contacts normally open and normally closed. That is what I used on mine.
« Reply #5 on: December 03, 2012, 11:14:23 PM »
I'll try Napa in the morning autozone said they can order them. Take about a day to get in. TIA
olddog1946
Moses Lake, Wa
« Reply #6 on: December 04, 2012, 09:07:51 AM »
I have some extra relays with both NC and NO contacts and the plug in for them. If you don't find one, send me a PM with your address and I'll send you one.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: December 04, 2012, 09:41:48 AM »
Relays with five terminals are typically configured to be either NO or NC.  These are quite common.
« Reply #8 on: December 04, 2012, 05:26:41 PM »
I ordered one today from autozone supposed to be here tomorrow. We'll see. Not all 5 pin are the same. Difference is one has two 87 pins and the one I need has a 87 pin and a 87a pin. 87a is normally closed and when trigger it drops out and the 87 is connected.
« Reply #9 on: December 09, 2012, 06:11:18 PM »
update. I got the correct relay from napa. off the self it is an air/ heat relay. Sorry the numbers are at home. Anyway CC still didn't work and is now in a pile on garage floor and a new one has been ordered. The purple wire where it plugged into the servo had shorted out are something and had melted the plug together and the hole into the servo was about twice its normal size. So I don't know if the relay went bad and caused this or the servo went bad and caused that. The CC had served me well for at least 6yrs and 60-70 thousand miles in all kinds of weather so I'm not gonna gripe about it. New one was almost twice the price as the orginal one so maybe it'll last twice as long.So Merry Christmas to me.
« Reply #10 on: December 10, 2012, 08:04:37 AM »
New one was almost twice the price as the original one so maybe it'll last twice as long.
That's why designer jeans are so expensive...they last that much longer!  cooldude
