February 06, 2026, 04:20:51 AM *
Author Topic: quick question  (Read 1616 times)
captsharky
Been riding Honda since 1972.
Sunrise, Florida
« on: December 06, 2012, 08:46:43 AM »
OK, I should know this, I don't have an owners manual for my Std. What is the amber lamp in the middle of the headlamp? Is this Temp?
2001 Valk black Interstate,
1998 T Cobra light bar, Corbin seats  Tank bib, baker air wings, lockable hard bags, luggage rack and trunk. Woody's faring, cruise throttle lock.
Daniel Meyer
The State of confusion.
« Reply #1 on: December 06, 2012, 09:00:05 AM »
Turn Signal. Should flash when either signal is on.
CUAgain,
Daniel Meyer
captsharky
Sunrise, Florida
« Reply #2 on: December 06, 2012, 09:19:44 AM »
OK, left is the neutral, what are the other two, I thought the right was the turn signal? I am getting a light amber glow from the middle one?
tank_post142
south florida
« Reply #3 on: December 06, 2012, 09:31:50 AM »
lt to rt: neutral turn bright beam.
check your turn bulbs to see if one is burned out
I got a rock Sad
VRCCDS0246
captsharky
Sunrise, Florida
« Reply #4 on: December 06, 2012, 10:08:26 AM »
Thanks, Yep one is out, got the LED's from Crome Glow out in Coral Springs. They are are going to replace it on Sat. lifetime waranty! I was afaid it was heat or oil but the oil is on the tact. So how you doing, I missed you a couple of times we were coming in and you were leaving.
tank_post142
south florida
« Reply #5 on: December 06, 2012, 12:00:17 PM »
yes, i'm usually a victim of the old in and out. crazy2
you heard Jeff was killed i assume? understand if you guys don't make it on Sat. will run into you sunday at the toys for tots run. Tank
I got a rock Sad
VRCCDS0246
« Reply #6 on: December 06, 2012, 12:06:32 PM »
The service manual can be downloaded from Dag's site in Norway, see below.
http://www.valkyrienorway.com/download.html
My rides:
« Reply #7 on: December 06, 2012, 04:44:19 PM »
The lights have little pictures on them that tell what they are.........
« Reply #8 on: December 07, 2012, 08:28:29 AM »
This indicates an electrical problem for sure.
With all the added-on modifications, finding the source of the problem can be very extensive.
I suggest to start disconnecting the added on electrical equipment until such time the light stops glowing.
Losing a ground probably will end up being the cause of your problem.
captsharky
Sunrise, Florida
« Reply #9 on: December 08, 2012, 10:41:34 AM »
It was the running light, they are LED, base went bad. Got that fixed and some clear lens front and rear and added two small LED strips up to the fairing to remind me to turn turn signals off. It was late when I got in add my old eyes to the mix and if you look at the picture you can see with the Woody Fairing, it hard to see the lights on the headlamp.
Tank, several of the guys will be there today, and we will be parking bikess tomorrow, and after I will be out at the park. Hope to see you and catch up.
