February 06, 2026, 05:56:10 AM *
Author Topic: Feedback Needed  (Read 2291 times)
ValkFlyer
Antioch, CA
« on: December 06, 2012, 06:38:55 PM »
I’m approaching 110,000 miles on my Valk and thinking that I’m going to have to service/replace my clutch sometime soon.  I’d like to begin prepping for the components that I'll need to buy and would like to know what I should be looking for.  Sure would appreciate some feedback from those of you who are well experienced in addressing this work.
« Reply #1 on: December 06, 2012, 06:49:56 PM »
Are you having problems with it?  A clutch should not be a mileage sensitive periodic service.  No reason it won't last as long as the rest of the bike.  Hoser   ???
Rio Wil
« Reply #2 on: December 06, 2012, 07:14:42 PM »
Try this little clutch health check.  Run up to 4000 rpm in fourth gear. Hit the throttle hard and then very quickly pull in the clutch(just a quick blip) and release the lever with the throttle still pinned (rpm with jump to 6000+).  If the rpm is quickly pulled back down towards the 4000 level, the clutch is fine.  If the rpm stays elevated or increases, then there is a clutch issue.  Could be worn clutch plates or it could be too heavy weight oil used in the engine.  I had to drop from 20-50 M1 down to 15-40 Rotella to keep my clutch from slipping. That was at about 130K miles and it now has 179K with no hint of slippage.
This might seem a bit brutal on the clutch/engine, but is really not much different than speed shifting through the gears.
ValkFlyer
Antioch, CA
« Reply #3 on: December 06, 2012, 08:10:05 PM »
No issues, although I'll give Wil's test a try tomorrow, just like to be prepared.
« Reply #4 on: December 07, 2012, 08:16:11 AM »
This could be destructive testing so beware!
Pay attention to Hoser's comment. He's "right on".
Disco
Republic of Texas
« Reply #5 on: December 07, 2012, 07:55:08 PM »
Unless you have a '98 with its original damper plate that is, like many have been, prone to rivet failure.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
valky1500
MI
« Reply #6 on: December 07, 2012, 08:39:17 PM »
Nothing kills a clutch faster than using the wrong oil.  Grin
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.  Wink
saddlesore
« Reply #7 on: December 08, 2012, 08:31:31 AM »
I have 102,000 on mine but 99% of that is highway riding. I would think stop and go riding would be harder on a clutch.
DARE TO BE DIFFERENT
ValkFlyer
Antioch, CA
« Reply #8 on: December 08, 2012, 12:50:29 PM »
While I appreciate the thoughts I'll I was looking for was some feedback on key components that might eventually fail.  If there's someone out there that would care to share that would be great.
RP#62
Gilbert, AZ
« Reply #9 on: December 08, 2012, 05:41:16 PM »
The folks that have done clutch work have done so because the rivets failed, or they're beefing it up to handle additional torque (commensurate with supercharger).  I could be wrong, but I don't think I've seen any posts regarding clutch work needed because it wore out.
-RP
valky1500
MI
« Reply #10 on: December 08, 2012, 09:52:32 PM »
The fact of the matter is for obvious reasons...
that wet clutch plates don't burn out...
but the the dry ones do.    2funny
Dry clutches will wear faster than a wet clutch (in general).
The wet clutch plates that do wear out...
come from using the wrong oils.     Cheesy
'98 Standard
'01 IS
chrise2469
Winnipeg Manitoba Canada
« Reply #11 on: December 08, 2012, 09:52:58 PM »
-RP
As Rp mentioned the most common failure of clutch component failure is the rivets coming out of the pressure plate(plate b, clutch on parts fiche) on 97/98 year bikes.  The most common symptom's are clutch handle only goes halfway, and slipping under hard acceleration.   If you do a search for clutch rivet in the old shop talk, you'll find some very good write ups and photos.  I'm not sure if there is a way to tell if you have a bad one or not until it starts to fail.
Any early clutch failure can usually be attributed to some other failure: blocked orifice in the master cylinder, sticking slave cylinder (usually squeaks first) or just plain old abuse-.
The clutch is pretty solid, if you want to to have all the parts waiting you can order it up but that's 3-400 bucks I could spend somewhere else.  Even in the wilds of Canada, it takes less than a week to get all the parts, although at twice the price Angry.
Hope this helps you.
ValkFlyer
Antioch, CA
« Reply #12 on: December 09, 2012, 11:11:25 PM »
-RP
Thank you RP and Chrise.
PSUbag
Huntingdon, Pa.
« Reply #13 on: December 10, 2012, 07:55:14 AM »
The damper plate (the one with the rivets) and the clutch spring were the only parts I needed when my clutch took a poop. Definitely get a new clutch spring, even if they tell you "it looks within specs." Trust me.... Undecided
MP
North Dakota
« Reply #14 on: December 10, 2012, 08:51:09 PM »
-RP
Added spring plates to mine with the supercharger.  You can tell the clutch lever pulls harder!  LOL
MP
"Ridin' with Cycho"
tank_post142
south florida
« Reply #15 on: December 10, 2012, 10:05:07 PM »
i replaced the damper and spring only when mine failed around 335,000 or so. has over 100,000 more on the clutch now and no problems.
I got a rock Sad
VRCCDS0246
