February 06, 2026, 06:11:10 AM
Valk engine specs
Topic: Valk engine specs (Read 1735 times)
jarid
sacramento CA
Valk engine specs
December 18, 2012, 05:38:38 PM »
Hello to all, I have just installed a engine analyzer (software program) on my computer. And was wanting to do some analyzing of the Valk engine so I will need some help with all of the numbers. Where can I find.
bore
stroke
valve lift
duration
valve diameter
rod length
deck height
combustion chamber CC
(GET THE POINT)?
and all of that type of info?
Thanks in advance
Thinking men cannot be ruled!
Madmike
Campbell River BC, Canada
Re: Valk engine specs
December 18, 2012, 06:40:36 PM »
http://www.valkyrienorway.com/download.html
get the service manual here........
mmurffy03
03 standard
toms river new jersey
December 18, 2012, 06:48:29 PM »
after all the specs are uploaded what will this program do ?
Dorkman
San Carlos, CA
December 18, 2012, 06:57:36 PM »
And what's the name of the program? Anything you stick up a tailpipe or on a plug or ICM and feed back to the computer? Interesting...
Last Edit: December 18, 2012, 07:04:50 PM by Dorkman
jarid
sacramento CA
December 19, 2012, 06:00:28 PM »
What this software does is allow to build a virtual engine,and then analyzes the performance characteristics of said engines giving you very detailed info about the engine. Then you change (Virtually) thing like cam specs,carb size,exhaust length/diameter,compression ratio or anything else that you can think of and this program will tell you what affect these changes will have. It will also make suggestions and point out flaws in engine set-up.
Thanks for the replies keep them coming.
wdvalk
Katy Texas
December 20, 2012, 04:57:24 AM »
what program is it?
custom1
01 Interstate
SW Pa
Reply #6 on:
December 20, 2012, 07:54:34 AM »
Quote from: jarid on December 19, 2012, 06:00:28 PM
Would be interesting to see what it finds. Not much I would think/hope.
John
jarid
sacramento CA
Reply #7 on:
December 20, 2012, 04:44:42 PM »
It is called pro engine analyzer 3.3
