February 06, 2026, 06:12:40 AM
Extended brake/clutch levers
Topic: Extended brake/clutch levers (Read 1462 times)
andycz1
Glendale, Az
December 20, 2012, 10:33:09 AM »
Anyone know where I can find longer levers for my 97 Standard?
Preferably in chrome.
Re: Extended brake/clutch levers
December 20, 2012, 01:34:55 PM »
Kuryakn. Have a set on my I/S. Look and feel way better than stock. Amazon-evil bay-go to Kuryakn web site and i know i'm missing a lot. RIDE SAFE.
Attic Rat
VRCC # 1962
Tulsa, OK
December 20, 2012, 02:18:01 PM »
Use the goldwing 1800 adjustable levers here is a link
http://www.kuryakyn.com/Products/136/Chrome-Adjustable-Lever-Sets
andycz1
Glendale, Az
December 20, 2012, 04:10:00 PM »
So these are longer then the stock ones?
MP
North Dakota
December 20, 2012, 04:19:50 PM »
Quote from: Attic Rat on December 20, 2012, 02:18:01 PM
Have these on my three Valks. Like them a LOT.
Longer? Not sure. Why do you want longer?
The adjustable 1800 ones are wider than stock, and pull much easier, if that is what you are looking for.
MP
"Ridin' with Cycho"
andycz1
Glendale, Az
December 20, 2012, 04:30:26 PM »
It seams when my hand grips the clutch lever my pinky hangs over, so a longer lever would be ideal.
I guess I have big hands.
Reply #6 on:
December 20, 2012, 04:45:19 PM »
Quote from: andycz1 on December 20, 2012, 04:30:26 PM
The Kurys are longer. RIDE SAFE.
Blackduck
West Australia
Reply #7 on:
December 22, 2012, 12:39:00 AM »
I used the Goldwing adjustables and if I remember correctly they are slightly longer, not at the house now so cannot check for sure. I did not check when I bought them and were sent black anodised ones. Not sure if Honda do a chromed/polished alloy unit.
If you go with them you have to cut a small lug off on the clutch lever.
Cheers Steve
amazngrace
Eastern Shore, Virginia
Reply #8 on:
December 25, 2012, 03:30:58 PM »
I put the stock GW 1800 levers on the IS and they are about 3/8" or so longer. The chrome Kury levers for the 1800 should be the same length, and like Blackduck says, you'll have to cut a tab off the clutch lever. Took all of 3 min. on mine and easy to see what to cut comparing the Valk and 1800 levers.
...ED
99 Red and Black IS
