January 28, 2026, 09:35:35 PM *
Author Topic: I/S headlight change....i'm confused  (Read 2371 times)
bg
Cumming, Ga
« on: June 16, 2009, 02:22:14 PM »
is there a headlight adapter ring on the stock set up?
the article in shoptalk had a link to electricalconnection for purchasing
an adapter ring.
is there one of these on my bike now or do i have to buy one?
i like to have everything i need when i start working on it.
thought i'd try the 9003 bulbs. walmart has them for $11.88 for two.
honda dealer wanted $30 for an oem bulb and i assume it was one bulb.
i'm not a mechanic and i have big hands but i want to give it a try.
MNBill
Southern Minnesota
« Reply #1 on: June 16, 2009, 02:31:39 PM »
Consider the h-4 bulbs,,, they are teh MC application and supposedly more Heavy Duty but same as 9003
MNBill
SE Minnesota
Kingbee
VRCC# 576
Northern Illinois
« Reply #2 on: June 16, 2009, 02:37:36 PM »
and no adapter ring needed.  Just bend/snip a tab or two
1999 Interstate
2000 Interstate
2004 Rune
Raverez
No good deed goes unpunished
Central New York State
« Reply #3 on: June 16, 2009, 07:20:31 PM »
HDL has them for 21.36 plus shipping.
http://www.hdlparts.com/fiche_section_detail.asp?section=148529&category=Motorcycles&make=Honda&year=1999&fveh=3473
bg
Cumming, Ga
« Reply #4 on: June 17, 2009, 01:07:10 PM »
i didn't have much time yesterday but i did try and unplug the connector.
dang, it is on there good.
i'll play with it some more when i get a bulb and have more time.
oh, and i need to put my hands on a diet. sure is a tight fit.
Baloo
Rimouski, Canada
« Reply #5 on: June 17, 2009, 01:59:23 PM »
You might want to try the Ultra Silverstar. They are a lot brighter. Had them for one year with no problem. As said above, you just have to snip the bottom tabs and put them on.
Never ride any faster than your guardian angel can fly...
Raverez
« Reply #6 on: June 17, 2009, 03:47:39 PM »
Will they still be properly aligned when you snip/bend the tabs?
PharmBoy
Lawton, Ok
« Reply #7 on: June 18, 2009, 04:42:01 AM »
I can highly recommend the Silverstar Ultras.  Well worth the extra cost.  I also used the adapters and everything works well...JTL   cooldude
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Cattman
Franklin, IN
« Reply #8 on: June 18, 2009, 05:10:39 AM »
I discovered  a long pair of needle nose pliars with a 90 degree end can get a much better grip on the connector than I can even with the speaker panels off.  cooldude
cutter
Plantersville, Texas
« Reply #9 on: June 18, 2009, 06:59:20 AM »
I use the 9003 cool blues Sylvania's in my I/S.  I just bend the 2 lower tabs back and put them in. No adapter used, just plug and play with no problems. DO NOT remove the screw that holds the bulb retainer arm.
