January 28, 2026, 09:45:11 PM *
Author Topic: Front wheel bearing removal problems  (Read 2707 times)
Keith in SC
« on: June 17, 2009, 07:40:52 AM »
Finally time for a new front tire, and when I took of the wheel, my suspicions were confirmed.  One front wheel bearing was VERY tough to turn.  ( Bike was very difficult to roll out of the garage, especially compared to my buddies Valk)
Not a big problem, I reach into the tool box for the spare set of bearings to swap in.
BUT, I can't get to the old one out of the wheel.  I thought it would just pop out, or need to be tapped out from the other side with a long drift punch.  But no luck.  I did pop off the bearing seal to look at the balls.  Looks like the cage was preventing it from rotating smoothly.  55,000 miles.
Am I missing a trick?  Or is there some special/expensive/backordered tool I need to buy from the stealer? tickedoff
Thanks in advance,
Keith in SC
« Reply #1 on: June 17, 2009, 11:15:48 AM »
The bearing should come right out fairly easily.. You're doing the right thing as far I can tell from your post.. If your going to change both bearings then maybe try removing the 'good' one and see if comes out easier.. If it does then that will give a lot more ' whacking room' to get the bad bearing out..
« Reply #2 on: June 17, 2009, 11:43:52 AM »
If the bearing outer ring has not spun in the wheel, it should come right out with a tad bit of persuasion.
Remember, there is a lip on the back side of the bearing in the hub.  Are you beating on it or do you have your drift in the little notch in this extra material..
The material I'm referring to is what the bearing taps in and rests on when installed.
DO NOT FORGET to put the spacer back inside the hub.....
Master Blaster
Deridder, Louisiana
« Reply #3 on: June 17, 2009, 02:15:07 PM »
You can drift it out from the opposite side, you just need to displace the center spacer that goes through the wheel that the bearings set on, that will give you access to the back side of the bearing.  Also you can get it out with a slide hammer if all else fails.
daytona
Port Orange, FL
« Reply #4 on: June 17, 2009, 02:56:15 PM »
make sure your on the brg! and get a BFH!    Wink
Just started!
DeathWishBikerDude
« Reply #5 on: June 17, 2009, 03:45:58 PM »
Anyone have an american supplier for bearings with part numbers?
I should probably replace mine at my next tire change.
« Reply #6 on: June 17, 2009, 04:10:27 PM »
Jeff K has a cross over list.
It is:
http://www.jkozloski.com/generic_parts.htm
Save it...............
John U.
Southern Delaware
« Reply #7 on: June 17, 2009, 06:48:54 PM »
Keith, try this suggestion on Que Express' site: http://hammer.prohosting.com/~schutzrs/bearing.htm
Keith in SC
« Reply #8 on: June 18, 2009, 04:33:47 AM »
I got the bearing out.  Just needed a bit more 'persuasion'.  The one bearing was VERY firm in the wheel, the other just needed a firm tap to remove.  Trying to get my punch on the bearing with the spacer in the way was a P.I.T.A, finally we found just the right tool that fit.  An old screwdriver with the tip bent over 90°.
Same thing putting in the new set, the problem side needed pretty hard taps to get it seated.  Wheel spins a lot more freely now.
Once I had that taken care of, we put on a new AVON Cobra.  Balanced out perfectly, no weights needed.  Haven't tested it yet, too rainy.
Thanks for all the advice everyone. cooldude
Keith in SC
T.P.
Apple Valley, Minnesota.
« Reply #9 on: June 18, 2009, 01:42:17 PM »
I just ordered all 4 for $29 + shipping   http://www.vxb.com/page/bearings/PROD/Kit6936   need 1   http://www.vxb.com/page/bearings/PROD/6204-2RS-1  need 3  cooldude
6jugzz
LUV2RIDE...buy safety chrome
Rock hill,SC
« Reply #10 on: June 19, 2009, 06:43:33 AM »
 Next time, U can get bearing pullers from Advance (borrow) for free. Try a little heat from a heat gun on the alumn around the bearing. It will heat up fast and grow some what, then knock it out from other side. A little penatrating oil might help too!
