January 28, 2026, 09:37:01 PM *
Author Topic: DEAD BIKE / STARTER RELAY?  (Read 2716 times)
thewoodman
Bradenton, FL
« on: June 17, 2009, 09:01:47 AM »
My '97 Tourer is reliable to a fault. But now I have a dead one in the garage. I have good battery, headlights, signals, horn, all power. When I push the starter button, headlights go dark, high beam and neutral lights on headlight bucket go away too. I had bypassed the side stand switch a few years ago and replaced the starter relay about a year ago. Any ideas where to look. It seems like a starter relay to me especially since the relay and the plug seemed to be glued together.
thanks in advance.
TheWoodMan
« Reply #1 on: June 17, 2009, 09:12:59 AM »
Check that and your starter button switch.
thewoodman
Bradenton, FL
« Reply #2 on: June 17, 2009, 10:21:40 AM »
If the starter switch was dead, would the lights go out?
TheWoodMan
thewoodman
Bradenton, FL
« Reply #3 on: June 17, 2009, 10:22:38 AM »
Is there a way to jumper the starter switch to check that angle? or is there a way to jumper the relay to check that out?
TheWoodMan
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #4 on: June 17, 2009, 10:50:58 AM »
If it was the Starter Relay, the whole bike would be dead.  No lights, no nothing.
Possible ground problem?
Black Dog
Don't you know...
« Reply #5 on: June 17, 2009, 11:29:33 AM »
Yes. Every time you press the starter button to start the bike, the head light goes out. It needs all the juice it can to start the bike.
« Reply #6 on: June 17, 2009, 11:31:01 AM »
You can have the switch apart and cleaned in 5 min. Thats a good place to start, esp if it has never been done.
« Reply #7 on: June 17, 2009, 11:37:31 AM »
Black Dog
Hey young feller up there in Wiskeyconsin.  "would be dead", NOT always...
Some you can turn the engine over but no fire to the plugs with the relay out.
My 1st one was dead in the water, cause everything had melted in the connector, my last one, pictured, would roll the engine over, just no fire.......
Here is the replacement to use if it is out.
You will have to move the big red wire to a different slot.  Move it to where it matches the old unit.  This kit is for an older Gold Wing...  Valkyrie, they want to sell you the whole loom.
thewoodman
Bradenton, FL
« Reply #8 on: June 17, 2009, 11:42:49 AM »
thanks for the info / looks like my new project after work / got to get it done before we head to our house in SE Tennessee next week / that's where I lost the starter relay last year
TheWoodMan
Warlock
Magnolia, Ms
« Reply #9 on: June 17, 2009, 11:48:22 AM »
So many people has problems with the starter switch and Honda sells them for around $70.00 bucks. When I get home I'm working on something that will do away with that switch and install a different one. The one I plan on using can be bought at any local auto store for less that $20.00 bucks. Once I get all the info together I will post it. On the starter issue switch you can turn the key on and jump across the two main wires. If it turns over and cranks you have a starter swtich issue. Also even though it turns over if any of the wires that plugs into the starter switch are corrided it will not start.
David
greggh
OMAHA NE
« Reply #10 on: June 17, 2009, 09:28:34 PM »
If when you push the starter button do you here the syliniod clicking?
If so then.
Take your side cover off, put bike in nuetral, uncover the rubber protecting the battery cable conection at the starter syliniod and cross the starter conection and the battery conection.
If it turns over - then replace you starter syliniod.
This happend to me about 2 months ago, local bike store had a Goldwing Starter silyniod in stock, works just fine now.
You could try tapping on the syliniod with a screw driver while pushing the starte switch.
thewoodman
Bradenton, FL
« Reply #11 on: June 18, 2009, 04:22:38 AM »
Rebuilt kill switch and all is good again / thanks for thehelp as always
TheWoodMan
