February 06, 2026, 06:12:20 AM *
Author Topic: Change of low radiator hose  (Read 1129 times)
frenteacasa
Madrid, Spain
« on: January 01, 2013, 03:27:05 AM »
I have to change the antifreeze and will take advantage to change also my low radiator hose (it has a small leak). Can I drain completely the fluid by simply removing the hose or do I need to remove also the bolt under the water pump??
Thanks a lot in advance
wdvalk
Katy Texas
« Reply #1 on: January 01, 2013, 04:41:08 AM »
just remove the hose
frenteacasa
Madrid, Spain
« Reply #2 on: January 01, 2013, 07:46:13 AM »
Thanks a lot!!
« Reply #3 on: January 01, 2013, 08:30:13 AM »
I'd do both.  If your goal is to replace the fluid, you want as much as possible out and the bolt is just a little lower.  It's just a bolt and will take about as long as it took to type your question. Wink
