February 06, 2026, 07:45:01 AM *
Author Topic: Which is closer  (Read 1553 times)
« on: January 04, 2013, 06:38:58 PM »
to our 150/80-17 front tires on a stock Valkyrie?? 130/90-17 or a 150/70-17. Thinking about going double D/S.  cooldude And as always T I A.  Wink RIDE SAFE.
olddog1946
Moses Lake, Wa
« Reply #1 on: January 04, 2013, 07:32:29 PM »
I believe the 130/90/17 is the closest in diameter. That's what I'm running on mine, backwards D404.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: January 04, 2013, 10:29:08 PM »
Height of tire from bead to tread;
Front stock
150/80HR-17 120mm
130/90-17 117mm
140/80-17 112mm
140/90-17 126mm
150/70-17 105mm
160/70-17 112mm
150/90-17 135mm (but I have no idea if it will fit).
I have the D404 130/90-17 bias rear on now and like it. Photo is at 17K miles.
If I can find one in 140/90 I might try it to make the speedo more accurate.
Fred.
« Last Edit: January 04, 2013, 11:38:38 PM by PhredValk » Logged
VRCCDS0237
« Reply #3 on: January 05, 2013, 08:12:03 AM »
Thank you PhredValk. That chart is zackly what i needed. I've found the D 404 as low as $100.95 at Bike Bandit. But with that size chart i can check some other options. RIDE SAFE.
« Reply #4 on: January 06, 2013, 07:01:41 AM »
I found the Dunlop D404 Rear Tire   Part #: 331-0516   Size:130/90-17  $99.71 including shipping from Chaparral Motorsports.
