February 06, 2026, 07:59:00 AM *
Author Topic: Brake fluid  (Read 1503 times)
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« on: January 07, 2013, 05:29:12 AM »
Fixing to change brake fluids. What type should I use?
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
JC
The Beast
Franklin, TN
« Reply #1 on: January 07, 2013, 05:59:00 AM »
DOT 4
« Reply #2 on: January 07, 2013, 07:25:23 AM »
There's kinds that don't mix. It is scary when you don't know what the last guy put
in there.
There's a very common valvoline dot3/dot4 kind I've always used...
I recently rebuilt my front brake master cylinder, I had never done it before. It turned out to be
easy. I rebuilt the caliper at the same time, that is certainly easy. I'm just saying this to reassure you
that if you put something in there that reacted poorly to whatever residue from the old stuff that
was in there, it wouldn't be too much of a disaster.
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #3 on: January 07, 2013, 07:30:07 AM »
in there.
Thanks hubcapsc, I'll keep that in mind....
GEORGE ELIOT
Hooter
S.W. Michigan
« Reply #4 on: January 08, 2013, 06:43:28 PM »
   +1 on the Dot 4. If you have a vacum bleeder you will have it made. If not make sure when you depress the brake lever don't completely do so. Only go part of the way. Don't let the resevour get empty either.
« Reply #5 on: January 09, 2013, 02:26:53 PM »
  My 99 has 50k on her and I had only changed the fluid once in the 12 years I've had her. I left the master cylinder alone but I did rebuild the calipers. I thought I had power brakes after the refurbishing.
Bronson
Belvidere, IL.
« Reply #6 on: January 09, 2013, 07:40:32 PM »
I tried using speed bleeders last year, they are awesome, and make the process easy to do for one person alone. They are made in Illinois, and have a check valve inside that opens and closes the bleeder as you squeeze the brake lever or clutch lever. I change brake and clutch fluid in all the bikes every year. Hope your fluid change goes easy!
Bronson
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #7 on: January 09, 2013, 08:02:59 PM »
Thanks everyone for the advice...I'm gonna give it a try tomorrow....
GEORGE ELIOT
CB1
DFW, TX
« Reply #8 on: January 14, 2013, 08:06:09 AM »
When I had my tires changed this weekend I asked the mechs to change and flush all of the brake fluid. (brakes and clutch).
When I picked it up later on the mech told me that it was good I did that because there was a lot of buildup in the master cylinders. The little window is again clear instead of brown and everything feels better.
I let the mechs do it because I have rotten luck and I'd probably melt all the paint off of the tank.  crazy2
Thanks!
Chris
