February 06, 2026, 09:35:01 AM *
Author Topic: Shifter shaft seal leak  (Read 3810 times)
rleggs
« on: January 09, 2013, 06:13:56 PM »
  Any tricks to changing the shifter shaft seal. A slight seep allows drippage onto the headers after sitting for a few weeks. Looks like a screw into the seal and a pair of vicegrips will do the removal or is it more to it than that?
« Reply #1 on: January 09, 2013, 06:16:49 PM »
thats all it takes, or a hooked ice pick.  However, when mine startes seeping I ordered the seal and while I waited for it to come it I removed the shifter, placed a socket the same size of the OD of the seal up againsted and gave it a tap or two with a mallet.  It seated a bit and stopped leaking for over a year.  When it started again I changed it and it was easy just like you said
« Reply #2 on: January 09, 2013, 06:33:45 PM »
You've got it figured out, but this is fun anyhow...
http://lifeisaroad.com/valkshiftseal.html
valkyriemc
NE Florida
« Reply #3 on: January 10, 2013, 12:13:19 AM »
Note exact shifter position before and after. Saves time and a re-do...
Veteran USN '70-'76
« Reply #4 on: January 10, 2013, 02:25:08 AM »
Nice fix cooldude
rleggs
« Reply #5 on: January 10, 2013, 09:20:10 AM »
Thanks all, I'll try the reseating tap b4 I order the seal, mabie I can wait till I need something else and combine shipping.
Tropic traveler
Silver Springs, Florida
« Reply #6 on: January 10, 2013, 10:48:44 AM »
I took an old, very long screwdriver & ground it down to a very sharp tip. After taking off the shift arm it makes short work of the seal. Has to be long enough to be used like a lever against the header pipe after piercing the old seal.  cooldude
'13 F6B red for Kim
« Reply #7 on: January 10, 2013, 06:12:23 PM »
    I used a sheet metal screw and my short vice grips. No problemo. RIDE SAFE.
Brian
Monroe, NC
« Reply #8 on: January 13, 2013, 04:58:22 AM »
Thanks for sharing this hubcapsc. It was an enjoyable read.
rickeym
2000 Blue & Silver Interstate
Denham Springs, La.
« Reply #9 on: January 13, 2013, 05:24:11 AM »
gotta love this tech board. great feed back Smiley
I'd rather ride a Honda than push a Harley
