January 28, 2026, 09:45:39 PM *
Author Topic: either a carb or petcock problem, HELP!  (Read 3133 times)
trantony
Keep the shinny side up and rubber side down!
Baton Rouge, La.
« on: June 18, 2009, 07:42:14 PM »
Calling all carb techs! Having issues with my "97 Valk idling at about 400rpm on cold start. When it heats up it idles at about 900-1100rpm. It fluctuates. If I set idle at 900 when I first start it, when it gets hot it idles from 1500-1700rpm, still fluctuates. I was wondering if I can check the petcock for leakage by connecting a mity-vac to the vacuum line at the #6 intake. I have done this, but it leaks down in about 4 seconds. Not sure I understand what the indications are of this? The bike has 64K miles on it, has been desmogged, good vacuum lines, and carbs sync'd. The air intake is 1 3/4 turns out. It runs great on hiway getting about 34mpg @ 70mph. Anyone got any ideas what is going on here? Thanx in advance. Ride safe and keep the shiny side up and the rubber side down.
 Undecided
Leon
VRCC #1860
1997 Valkyrie Tourer
2005 ST1300
2016 Polaris Slingshot SL LE
BonS
Blue Springs, MO
« Reply #1 on: June 18, 2009, 08:01:34 PM »
My 2 cents - Not scientific but I can pull the #6 vac line to the petcock and then, with my mouth, pull a vacuum on a good petcock and it'll stick my tongue to it indefinitely. You likely need to rebuild/replace it. I'm no help with the fluctuating idle but someone will come along soon.
Dennis Klinefelt
« Reply #2 on: June 18, 2009, 11:21:09 PM »
Are you using the choke..??
Kingbee
VRCC# 576
Northern Illinois
« Reply #3 on: June 19, 2009, 04:25:39 AM »
If your line to the petcock is good, then you need to rebuild the petcock.  It should have held a vacuum for a week.........
1999 Interstate
2000 Interstate
2004 Rune
« Reply #4 on: June 19, 2009, 06:04:34 AM »
There very well could be more than one problem.. The idle shouldn't fluctuate like that and that could a vacuum leak or a low speed jet problem.. [When you mention 1 3/4 turns on the air intake, I don't know what you mean.. I'm thinking your talking about the pilots].. You should be able to control your initial idle speed with the choke/enrichener and its normal for the engine to idle slower when the engine is still cold..
RTaz
Oscoda, Michigan
« Reply #5 on: June 19, 2009, 06:39:13 AM »
...replace your intake o-rings...be sure your airbox is on correctly ....be sure that the #6 vacuum line is correct size....and be sure you don't have a float sticking....also you may think about your timing belts....
 RTaz
FLATSIX
Heist o/d Berg BELGIUM
« Reply #6 on: June 19, 2009, 12:13:43 PM »
One question : do you have valance covers?
2 weeks ago I changed the O-rings in the intakes, have put back my valance covers, but I did it in another way as before : I first mounted the sparkplugcaps into the holes, so they fitted perfectly, but then I could not go under the valance covers to put the sparkplug caps firmly on the sparkplugs. I pushed them from on top and mounted the valance covers (so the caps were not fully on the sparkplugs!)
Then I did the synchronising of the carbs : result - when cold the motor idles at 500 rpm and not too steady (needle up and down)
I thought that it was due to the synchronising till I started to ask here on the board how to mount the valances : I redid it, pushed the rubber sparkplug tops firmly on the sparkplugs and then mounted the valances :result - idling with cold motor is like it should 700 - 800 rpm and very quick 900 rpm + idling is steady + bike runs even more better.
SO PLEASE CHECK THIS OUT IF VALANCE COVERS : SPARKPLUGCAPS MUST BE FIRMLY ON THE SPARKPLUGS ) !!
 uglystupid2
standard '97 - european F6C - red & white - 27.000 KM
trantony
Baton Rouge, La.
« Reply #7 on: June 19, 2009, 09:22:48 PM »
Thanx for help guys! I've about come to the conclussion that I may have a couple of problems. Possibly plugged slow jets and a bad petcock. BonS & Kingbee, I think we're on the same page with the petcock rebuild. Flatsix, not using valance covers, but I will check for plug connections. RTaz, what would be the best way to check for sticking carb float? Could this be done by draining float bowls and leaving drains open a few hours? Wouldn't a bad petcock give similar symtoms? I was reffering to the pilot screw adjusments earlier. Dennis, Ive always had to use choke for cold start ups. Isn't this normal?
Leon
VRCC #1860
2005 ST1300
Bone
« Reply #8 on: June 20, 2009, 03:30:47 AM »
I'm in a colder climate and used my choke for most start-ups. This spring I replaced the battery because of age it didn't show any signs of getting tired.
Now I can hit the button and she fires without the choke but I do use it occasionally to increase the idle for a few moments.
franco6
Houston, TX
« Reply #9 on: June 20, 2009, 08:24:52 AM »
here in houston i stop using the choke in march-april ,it starts right up. just let it warm up a bit.
Enjoy the ride!
Medic
Rural Hall, NC
« Reply #10 on: June 21, 2009, 02:58:42 AM »
trantony...mines been doing the same thing (97 also). I've got #38 slow jets and a petcock rebuild / cover set...just haven't had the time to do it. My Valk has also been DeSmogged and recently had the valves adjusted and carbs synced. The only thing different I have is right-sided exhaust popping when cold starting..Goes away after warmed up except for minor popping on decel at times. Not sure if I have the vaccuum leak like you or not. Let me know if the new jets and petcock rebuild works for you  cooldude. With my schedule...it may be towards the end of July for I get into mine.  Sad Also let me know how many "turns out" on the pilots you find works after the slows switched if you use #38's. The '97's had different carbs and the stock setting is different than other years...so I'm curious on what works when putting the #38 slows in a '97.
FLATSIX
« Reply #11 on: June 21, 2009, 02:42:17 PM »
Trantony and Franco6, you are not the only ones with problems on the '97 Valk!
I bought mine new and have the same issues - went during all these years several times to the Honda-dealer where I bought my '97 from and asked him about the misfiring from my left exhaust - the only answer that he could give was "that nothing is perfect
and with that I had to do it.
When I open throttle till 2200-2500 rpm I hear misfirings at the left. Another thing : while synchronising the carbs I was 99% of the time turning and adjusting the screws from the 3 left - the right side kept much more steady.
Checked already everything : O-rings,clamps, vacuum etc...... nothing to find but keeps misfiring - if you can find the cause or can cure yours '97- please let me know as I wanted to finally after 12 years ride it without the slight failure she has - for the rest she drives fine, oly the ennoying popping at the left  Angry
