February 06, 2026, 07:54:44 AM *
Author Topic: bearing question  (Read 1459 times)
« on: January 17, 2013, 07:34:13 PM »
is this part # a left rear bearing 91052?   I know I have the right bearing  91053 here and I have a ujoint in the bag ready to go
directline is showing this kit also for rear
http://www.directlineparts.com/product.asp?pid=106206&str=0&mdl=1540&mdy=2001
has anyone used it?
Do I need to buy seals as well and anyone have the part # for the directline seals
Thanks  and special thanks to NJF6cowboy who offered to come over and help me do the ujoint job next weekend    I want to make sure I have everything ready for him when he gets here
« Last Edit: January 17, 2013, 07:35:48 PM by Oss » Logged
Joevalk
Santa Fe, Texas
« Reply #1 on: January 17, 2013, 09:54:58 PM »
I would think that is a miss print . no way to adjust them coolsmiley
VRCC#32720
1999 Grn/Silver Interstate
olddog1946
Moses Lake, Wa
« Reply #2 on: January 17, 2013, 09:59:21 PM »
Oss,
I have the allballs set, part # 25-1020  or 41-6260.
It uses the 5204-2rdleft bearing with the  30-4709 seal and a 6204-2rs.
It does come with the bearings and seal.
Not sure if your part numbers are for a roller  bearing set as opposed to the ball bearing set these are.
« Last Edit: January 17, 2013, 10:02:00 PM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #3 on: January 18, 2013, 07:43:53 AM »
What is pictured there are not the correct bearings for the Valkyrie.
Whether the numbers are correct or not is questionable.
Stick with OEM and avoid any problems.
Why would anyone want to do differently?
« Reply #4 on: January 18, 2013, 08:25:21 AM »
The left rear bearing is the same as for the front wheel as long as the bike is a 1998 or newer.
« Reply #5 on: January 18, 2013, 10:33:45 AM »
All-Balls is Chinese made.
olddog1946
Moses Lake, Wa
« Reply #6 on: January 18, 2013, 10:53:00 AM »
hdlparts.com =
17    BEARING (6204UU)
91052-MAE-004    001    $21.62    $16.65
   18    BEARING (20X47X20.6)
91053-MN5-003       $58.93    $44.73
   19    DUST SEAL (30X47X8)
91253-443-762 (replaces 91253-443-761)    001    $9.53    $7.34
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: January 18, 2013, 01:01:11 PM »
thank you for the replies
I called directline and ordered all 3
the honda left rear bearing and the seal and the all balls set for front and rear
I like to carry spare parts in case someone on a trip (not necessarily myself) breaks down
edit
Now that I am home I can see I have both right and left bearing but did not have the seal
no big deal now I have 2 sets of spares   cooldude  which will carry me a few hundred thousand miles
always good to be prepared
« Last Edit: January 18, 2013, 04:08:45 PM by Oss » Logged
stude31
Topeka,ks
« Reply #8 on: January 21, 2013, 09:33:16 AM »
Oss,
I would suggest doimg the double row mod on the rear.  http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
