February 07, 2026, 12:07:23 AM *
Author Topic: Tick, tick, tick  (Read 1796 times)
Xtracho
The Bosses
Florida's Emerald Coast
« on: January 18, 2013, 03:20:23 AM »
While sitting at a red light the other day I noticed a light, almost imperceptible "tick,tick,tick" coming from inside the right valve cover. It's so slight that you really have to listen to hear it, but it's there. Lifter maybe?
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
fordmano
San Jose, CA.
« Reply #1 on: January 18, 2013, 03:32:05 AM »
Is the bike desmoged?
Possibly pare valves ticking.
Possibly Exhaust leak?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
9Ball
« Reply #2 on: January 18, 2013, 04:08:39 AM »
PAIR valves most likely.  Loose exhaust header nuts will cause similar noises.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Mallett
Oh, what a ride!!!!
Laurel, Mississippi
« Reply #3 on: January 18, 2013, 04:52:53 AM »
I had that tick....tighten the exhaust header nuts.....it's gone...
Any coward can fight a battle when he's sure of winning; but give me the man who has pluck to fight when he's sure of losing.
GEORGE ELIOT
Joevalk
Santa Fe, Texas
« Reply #4 on: January 18, 2013, 04:58:23 AM »
Tick tick tick is better than a clunk clunk clunk Evil  try the header boltz  angel
VRCC#32720
1999 Grn/Silver Interstate
« Reply #5 on: January 18, 2013, 05:06:58 AM »
Pair valve, mide does it at idle and its annoying.
Xtracho
The Bosses
« Reply #6 on: January 18, 2013, 06:15:56 AM »
Will have to determine if she is desmogged or not and will tighten header bolts. Sorry to be so stupid, but what are PAIR valves? Thanks!
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #7 on: January 18, 2013, 06:33:32 AM »
Part of the crap that disappears when you desmog, if you do a complete desmog.  Hoser  Smiley
Xtracho
The Bosses
« Reply #8 on: January 18, 2013, 07:37:28 AM »
Thanks Hoser!
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
« Reply #9 on: January 18, 2013, 07:53:26 AM »
Easy does it on tightening the header nuts, those studs have a habit of snapping off. Don't use a torque wrench, just snug them with a small box end wrench. Re. lifters....these engines don't have them.
« Reply #10 on: January 18, 2013, 08:22:00 AM »
Yep, the last thing to look at is valve lash. Like the boys said, exhaust retainer nuts [ 7 lb/ft, very easy with them], Pair valve assembly[ in the valley between the carburetors] and even the intake vacuum lines and caps.
An exhaust leak can be a real PITA to correct, sometimes they just don't want to seal.
But, all this said, when you get the chance, run the engine and listen carefully for the noise and try to really locate it. A stethoscope, screwdriver, dowel, tube can be used to help with this.
If it really appears to be coming from inside a valve cover, then a valve adjustment is in order. But, try the other stuff first.
YoungPUP
Valparaiso, In
« Reply #11 on: January 18, 2013, 06:50:24 PM »
Follow the small chrome tubes from the back top of the heads to in ubder the carbs.  Should be attached to a small metal box, those boxes are the pair valves.  no small chrome tubes and no metal boxes, then someone may have already done the desomg.   Could be a vacuum leak on the back of one of the carb intake tubes.  As for the header bolts, use a gentle touch.  6ft/lbs = leaky
7ft/lbs = tight  8ft/lbs = broken.  They break if you look at them funny, so don't get crazy...
99 STD (Under construction)
Xtracho
The Bosses
« Reply #12 on: May 26, 2013, 08:55:07 AM »
Just an update on this. Been a while. Got around to adjusting the valves this morning. Beautiful morning to do it. All were good except the #5 intake. It was a little slack as the .006 feeler gauge would pass right thru without any resistance. Adjusted that, buttoned everything back up, and took her for a ride. Tick, tick tick is gone. Good on me!
 Wink
Mark
In the stable:
'84 GW Aspencade
'47 Indian Chief
'98 Valkyrie
