February 06, 2026, 07:53:05 AM *
Author Topic: Rear Wheel Lubrication  (Read 1308 times)
desanshe
White Rock, British Columbia, Canada
« on: January 21, 2013, 07:14:44 PM »
Good evening:
I have a question regarding a car tire on my 99 Valk interstate.
I understand you get a lot more mileage with a car tire than a motorcycle tire.  I am concerned with the lubrication during this extended time period.
I had to replace the rear end on my bike once due to inccorrect lubrication used when I had a tire change.  I would like to be sure that the lubrication is checked on a regular basis.
Could someone please let me know the intervals the lubrication is to be checked and I assume that it is necessary to remove the rear wheel so this can be checked.
Thanking you all in advance
Roger
« Reply #1 on: January 21, 2013, 07:19:31 PM »
10000 miles and replace O rings. Also look at inspect the pinion cup. If your clutch fluid or brake fluid looks like old coffee it needs replaced also. Clutch and brake use D O T-4 fluid. RIDE SAFE.
« Reply #2 on: January 21, 2013, 09:29:14 PM »
+1 what o2s said.  The rule of thumb is about every 10,000 miles regardless of tire type or brand.
And yes, it's necessary to remove the wheel/tire to service.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: January 21, 2013, 10:19:19 PM »
I do mine each spring. I ride 12-14K miles in a season and it's always clean and sticky. If you ride a lot, 10K miles or so. If you ride less, each year just to be sure it doesn't get missed. AND every time you mount a new tire.
It isn't hard and takes just a couple of hours (less with no bags).
Fred.
VRCCDS0237
Daniel Meyer
The State of confusion.
« Reply #4 on: January 22, 2013, 05:57:24 AM »
And assembly order is more important than the lube.
Make sure the 4 nuts that hold the pumpkin to the swing arm are loose when you torque the axle down. Tighten them after that.
CUAgain,
Daniel Meyer
« Reply #5 on: January 22, 2013, 07:47:35 AM »
+1 with what Daniel said.  And, make sure you put most of the lube you use here and not just on the flange so it doesnt all get pushed off
« Last Edit: January 22, 2013, 07:59:07 AM by Chrisj CMA » Logged
