February 06, 2026, 07:54:30 AM *
Author Topic: IS Carb springs on Tourer  (Read 1944 times)
97Valk_CT_Euless
Euless Tx
« on: January 22, 2013, 06:14:29 AM »
I've seen on here that the IS carb springs will improve the throttle response of the Standard and Tourers.  (Not that it's bad anyway... but more is better, right?) Are we talking about spring #11 in the fiche? (97 CT #11=16050-MZ0-000, 2000 CF #11=16050-MBY-671).  Pretty reasonable at $2.42 each.  The reason I ask is that #12 spring (which I can't remember seeing on mine) is the same on both bikes (Must not be it) but the dagum thing is $10.83 each!!!
Just checkin.
9Ball
« Reply #1 on: January 22, 2013, 07:20:31 AM »
Here's what you need...
http://www.directlineparts.com/product.asp?pid=750&str=0&mdl=1539&mdy=1999
good luck
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: January 22, 2013, 07:30:47 AM »
The spring folks talk about changing is the large spring in the vacuum chamber not the small needle spring.
97Valk_CT_Euless
Euless Tx
« Reply #3 on: January 22, 2013, 09:55:30 AM »
Ok. Thanks guys. Seemed pretty obvious but wanted to be sure. Couldn't see how the needle spring would do anything but I guess I was as much as anything shocked at the price of the needle springs.
Thanks again.
rhinor61
Northern California
« Reply #4 on: January 22, 2013, 09:25:19 PM »
Pretty straight forward swap.
I saw more pull in the mid-range power band just like they say.
I did a dyno run after with 62,000 miles on the bike...
got 95hp and 105ft lbs of torque.
Did MPG suffer.. when you have this much power and beauty between you legs.. MPG is the last thing you should be thinking about.
Just keep the old parts.. in a zipper bag.. just in case...
have fun...
John
Cali.
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
97Valk_CT_Euless
Euless Tx
« Reply #5 on: January 23, 2013, 05:11:38 AM »
Thanks all.  Always keep everything (Ok, not old oil filters... I've been known to let an air filter hang around awhile though...) Even still have all the PAIR valves/fittings.  Yeah, my garage is a mess.
Chiefy
Sarasota, Florida
« Reply #6 on: January 23, 2013, 05:23:21 AM »
I feel your pain.
Disco
Republic of Texas
« Reply #7 on: January 23, 2013, 06:04:14 PM »
Hey Euless,
Not to rain on anyone's parade, but I did the IS carb spring mod a couple of years ago and couldn't tell the difference.  It's a cheap enough mod to give it a try if you want to, though.  Hopefully, you'll be like everyone else and be satisfied.
And yes, the springs I put in were different than the springs I took out.   coolsmiley
Next up for me is the IS ECM mod.  I've had one on the shelf for a while, just haven't gotten a round tuit...
Disco
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
97Valk_CT_Euless
Euless Tx
« Reply #8 on: January 24, 2013, 04:27:42 AM »
Absolutely want to get her an IS ECM. With the 4deg I have I think that'll be a sweet deal. Was thinking about the spring mod like you said, pretty cheap, and not too much time
 Reversable too. I'm more concerned about mileage than power, (she has plenty) and I doubt the springs help mileage, but I do succumb to the old girls wiles time and again, and she seduces me into rolling the throttle around.  Sure feels good.
« Reply #9 on: January 24, 2013, 04:36:56 AM »
the weaker I/S springs act like an accelerator pump by allowing the needle to rise faster thereby allowing more fuel sooner into the air stream. if the engine wants the added fuel it will make more power, if it doesn't need it then same or less power.
PharmBoy
Lawton, Ok
« Reply #10 on: January 24, 2013, 09:44:53 AM »
For me, the I/S ECM swap and the I/S carb spring swap didn't make it a rear tire smoker, but it did make any roll on of power much smoother and a little faster without any hesitation.  I think that both are worth the time and effort.  Each swap is simple to do and doesn't take very much time...Jim  Smiley
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Farther
Quimper Peninsula, WA
« Reply #11 on: January 24, 2013, 11:21:03 AM »
My experience too on my '03 Standard.  I was experiencing a mild surg at low speed/low RPM and that is completly gone.
~Farther
97Valk_CT_Euless
Euless Tx
« Reply #12 on: January 25, 2013, 05:49:23 AM »
Got too much money and time in the final drive to be smokin the rear tire anyway!   Smiley  But I do like to feel the power somtimes.  Also would like to eeke out as much gas mileage as I can, makes it easier to justify riding the old gal to work every day I can!  Then of course when she's saming me all this money, it makes sense to get that IS for road trips! he he
Brian
Monroe, NC
« Reply #13 on: January 25, 2013, 03:57:45 PM »
Thanks for posting this part info as I too wondering the same thing.
« Reply #14 on: January 26, 2013, 11:31:15 AM »
PS:   One package is all that is needed.    The set goes for $14.99 + ship/handling..
Valkpilot
What does the data say?
Corinth, Texas
« Reply #15 on: January 26, 2013, 11:56:40 AM »
That's a great, simple explanation, CA.   Thank you.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
