April 01, 2026, 11:25:30 AM *
Author Topic: Techno Metal Posts! Great product! Non Valk  (Read 1566 times)
« on: January 23, 2013, 05:52:47 AM »
I HAVE NO AFFILIATION WITH THIS COMPANY!  Just a happy customer cooldude cooldude
Here's a system I've had great experience with.  Called "Techno Metal Posts" their official term is:
"The techno Metal Post helical pile is like a giant metal screw that is installed by a certified technician using proprietary hydraulic machinery. The pier is augered into the ground until the desired bearing capacity is achieved"
I've used them on 5 or 6 projects and will never set a concrete poured pier in a sona tube ever again.  And I've got a mini excavator that will dig a hole in about 4 scoops.
I've done a two story house, a deck over the water on a lake, to a cottage lift (at present) using these and they make things a lot easier.  No digging, no cement pouring, no waiting, and ready to be built on as soon as they move the machine.
Above:
Inside the cottage I'm presently working on, lifting it, so the owner won't feel like she's going downhill when walking around Grin  It's bad.
Outside same cottage.  We ran three rows of 4 piers, one down the middle and one on each side. You can see one installed at bottom right.
One of the piers before install.  Their 7' long and come with a bracket to accept either a 4x4 or 6x6 post.  If 7' isn't deep enough, they add a post to the top and can go down 14'
This is a great idea and product.
tank_post142
south florida
« Reply #1 on: January 23, 2013, 06:09:38 AM »
I was expecting music  Undecided
I got a rock Sad
VRCCDS0246
bscrive
Ottawa, Ontario
« Reply #2 on: January 23, 2013, 06:13:57 AM »
Hey Hook,
What do they do if they hit a rock.  Will theses push it out of the way?  What if you hit bedrock and can't go down the 7', doe they cut them off and weld on the bracket to attach the 4x4 or 6x6?  I have seen these used up here but have been a little hesitant especially if you need the post in a specific spot for a deck.
Jess Tolbirt
White Bluff, Tn.
« Reply #3 on: January 23, 2013, 06:35:26 AM »
you will need dynamite to use those here,, nothing but solid rock around these parts..
Valkyrie member # 23084
« Reply #4 on: January 23, 2013, 07:33:15 AM »
Hey Hook,
The operator experience takes over.  I've seen them stop and go, shift from side to side or back and forth and almost always they get them in.  The machines arm moves left & right and extends out 10'.   On a couple, a poured footing was discovered and they cut a 1' section out of it to get by.  They carry a diamond saw and a electric jack hammer with them.  On a porch I did at my local pub, we hit solid rock at about 3 feet. We cut the pipe and moved on.  It's still there and hasn't moved at all after 18 months.
They can pretty much put the pipe where you want it within an inch or two.   The posts can also be put in at an angle of, I believe, 5 degrees and still be ok.
I guess you just scrap off the dirt and pin to rock?  These are designed to go lower than the frost line depth.  Not sure what it is in your area, but here it's 42".  They were invented in Canada where frost depth is much deeper.  The green plastic sleeve will move with the frost, not the post.
We hit bedrock/ledge here at places and don't need to go deeper if we do.
Although I've no proof, I heard Derick Jeeter, (NY Yankees) built a house ON a lake using these.
« Reply #5 on: January 23, 2013, 08:25:27 AM »
Thru decades of neglect and basement flooding, the house next door settled badly on the foundation.  A good guy bought it out of foreclosure pretty cheap.  An outfit came in and used the same technology to level the house.  Once installed, they use laser levels to get it exactly right.  When done, everything is covered up and stays in place.  For the huge price tag, he got a warranty.... if the house ever moves again, they come back out, uncover the capped subterranean jackstands, and level it up again.
« Reply #6 on: January 23, 2013, 08:47:58 AM »
I had a chain link fence moved last spring and they used a smaller scale post for the corners, and etc.     My other fence is leaning toward Murphy's and this one is still true to the level.
Both fences were put in within 30 days of each other.     So this spring, I'm going to have them straighten up the mess on the West side.     Snow has a tendency to push chain link fences over.   Especially if they are close to a bank.
« Reply #7 on: January 23, 2013, 10:40:57 AM »
From what I understand, that was the purpose these where originally invented for, lifting foundations that had sunk.  Someone figured out they had many more uses.
I'm not a fan of warranties and don't buy any extended ones.  With the expeirence I have now, I wouldn't buy one for these either.  Their pretty fool proof once installed, but then, anything can happen.
I haven't seen them used for a fence, kinda pricey for that.  But you could.
« Reply #8 on: January 23, 2013, 11:29:06 AM »
I don't know if these are from the same company, but they sure as hell look like them only in a smaller scale.
Price wasn't too bad.   Take out 100' of fence, move it over 14" and reinstall.   Cost me $350.     I felt that was a damn good price.   This was labor and parts.   They used my old top rail and fence.    Corner posts and the other posts were out of this stuff.
I'd shoot a picture of it but my damn camera isn't worked all that great.    I shot about 70 Christmas pictures and only got 7 good prints.     I'm going to take it out to the camera shop after this firkin flu bug flies up someone else's back side.   Will either have it fixed or buy a new one.
« Reply #9 on: January 23, 2013, 12:09:56 PM »
Me either, a have never paid (extra) for any warranty of any kind, and will never.
No, this warranty came with the purchase price.
