March 10, 2026, 04:42:01 AM
Zumo Users, Question...
Topic: Zumo Users, Question... (Read 1597 times)
Steve K (IA)
Cedar Rapids, Iowa
June 19, 2009, 11:09:55 AM »
How do you remove / delete a route from the unit?
States I Have Ridden In
NiteRiderF6
Doug n Stacy
Mississippi
Re: Zumo Users, Question...
June 19, 2009, 11:22:22 AM »
You can delete the routes from the Where To button, select routes, then edit and the delete option will come up, check them all and they are gone. This works on my Zumo 450...
On a Search I found this too: "The zumo is home, so I can't check it, but according to other thread, there is a single GPX file on the zumo in the Garmin folder that always has the same name and is regularly overwritten."
TwoDogs
1999 Interstate
Waco, TX
June 19, 2009, 11:31:31 AM »
http://www8.garmin.com/manuals/zumo450_OwnersManual.pdf
Page 16-17
If God dwells inside us like some people say, I sure hope He likes enchiladas, because that's what He's getting. - Jack Handey
Steve K (IA)
Cedar Rapids, Iowa
June 19, 2009, 03:57:39 PM »
Duh...
I found it. After highlighting a route and hit edit, you can flip to a second page where it say's delete. I didn't see that before. In the past, I deleted routes one way point at a time. I knew it had to be easier.
