April 30, 2026, 03:05:41 AM *
Author Topic: No power?  (Read 1288 times)
Baron
Trophy Club, Texas
« on: January 26, 2013, 09:43:39 AM »
I need some help to figure out what is wrong with my Interstate.
I was going to go out for a quick ride  Smiley and I turned the key heard a 'click' and then all the electrical on the bike went out  Sad.  Any ideas?  I put the battery tender on it and it went green but nothing is is turning on.
Any advice on where to start is very much appreciated.
Ride safe,
Baron
VRCC 28275
2000 Valkyrie Interstate
2023 Road Glide Limited
2022 KLR 650
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #1 on: January 26, 2013, 10:12:37 AM »
Isn't there one big fuse that controls all power on a Valk?
YoungPUP
Valparaiso, In
« Reply #2 on: January 26, 2013, 04:35:15 PM »
Isn't there an electrical junction point on the I/s that is known for burning up? down near or under the battery?
99 STD (Under construction)
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: January 26, 2013, 04:45:48 PM »
I'm betting on a bad battery based on a similar experience and it's a simple thing to take it to an auto parts store and have it tested.
But, it could be the starter relay and it could be the starter switch, so if it is not the bettery, look there.
« Last Edit: January 26, 2013, 05:41:48 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Red Diamond
Beaumont, Texas
« Reply #4 on: January 26, 2013, 05:30:28 PM »
Thanks Mr VP for the help you gave me on the switch repair when mine went south in South Carolina this past Labor Day Weekend. Now my switches gets a maintenance.
« Reply #5 on: January 26, 2013, 09:40:05 PM »
I have had the connections go bad at the battery terminals.  Mine went click and I had to take both cables off, clean them up, and put them back together.  Worked like a champ street the cleaning.
I guess the power surge was enough to let the corrosion separate the metals in the connection.
The battery went south about 3 months after the cleaning.
Hay Cool
Baron
Trophy Club, Texas
« Reply #6 on: January 27, 2013, 09:31:09 AM »
You were right, bad battery.  cooldude
All the connections look good going to the battery and I plan to check on that electical junction point next.
Thanks  Smiley for the help, you guys are great source of Valk knowledge.  cooldude
Ride safe,
Baron
VRCC 28275
2022 KLR 650
