January 28, 2026, 09:44:22 PM *
Author Topic: Front Wheel Installion ooops  (Read 2221 times)
CISE
« on: June 19, 2009, 05:05:31 PM »
Alright .. for anyone of middle level mechanical abilities (such as myself) with more tools than you REALLY know how to use (like me again) ... and with just enough knowledge to be dangerous (again myself as an example), here is a warning.
When replacing a front wheel after maintenance (such as replacing fork seals), the one thing the manual does NOT show is :
1. Ensure that the axle is FULLY seated on the left hand fork before tightening pinch bolts
2. Craftsman 3/8" ratchet extension make good driver pins .. but they do fit INSIDE the axle from the left side (including the bulge that hold the female socket potion).
 uglystupid2
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 19, 2009, 05:27:55 PM »
mine is flush with the left fork.  I have always just tapped it in until it is flush again.
FLAVALK
Winter Springs, Florida
« Reply #2 on: June 19, 2009, 06:22:01 PM »
If the axle end is not flush with the left fork, the rivet heads on the left rotor will drag on the caliper housing...there aint much clearance. I think 0.030 max...gotta be flush.
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #3 on: June 20, 2009, 07:32:57 PM »
 uglystupid2
The hexagonal hole on the left end of front axle is for a 17mm hex key wrench to hold axle in place while tigthening right side axle bolt.  I found this out last weekend myself    uglystupid2
