November 25, 2025, 06:44:25 PM *
Author Topic: IS fairing removal  (Read 925 times)
shortleg
maryland
« on: February 01, 2013, 06:16:48 AM »
  I would love if the next time someone removes
their fairing they could take a few pictures.
  Anybody got a few.
         Shortleg[Dave]
BigBad1
1999 Interstate
Garner NC
« Reply #1 on: February 02, 2013, 10:52:29 AM »
Mine is off right now. Too late to take pics of the procedure but will be glad to photo anything while it is apart. Are you looking for anything particular.
NITRO
Eau Claire, WI
« Reply #2 on: February 02, 2013, 12:51:04 PM »
Assuming the screws turn out without spinning their grommets loose, the whole job is pretty easy. The shop manual will tell you what you need to know.
For those stubborn grommets that come loose, JB weld does a nice job of fixing them for the next removal.
When in doubt, ride.
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: February 02, 2013, 06:06:41 PM »
Wish I saw this in the morning. I removed mine this afternoon, about an hour and not bad. I used these instructions from a thread by rocker333:
Remove the following:
4-screws on each speaker panel...
1-screw, each side, at top of gauge panel after speaker panel is removed...
2-screws, each side, holding the chrome trim inside fairing under the windshield...
4-8mm bolts holding the windshield on...
2-10mm bolts holding the vent scoop no need to remove...
2-sheet metal screws at the top after windshield is removed...
2-10mm nuts on turn-signal stay behind the speaker panels...
Bend back the wire stay in front of gauges to free wire harness going to headlights...
Now fairing and headlights will rotate down to the front fender...
Disconnect wiring harness to remove fairing completely from bike...
If any of the screws spin but don't loosen, just pry behind them while turning and the notorious
"Pem Nuts" will come out of the fairing.  You will need to epoxy them back in place before you re-install.
Fred.
VRCCDS0237
PhredValk
« Reply #4 on: February 03, 2013, 03:37:41 PM »
I just put some pix in http://www.valkyrieforum.com/bbs/index.php/topic,51617.0.html
Fred.
VRCCDS0237
Steve K (IA)
Cedar Rapids, Iowa
« Reply #5 on: February 03, 2013, 05:54:16 PM »
Removing the fairing is a much easier job than removing the gas tank.   coolsmiley
States I Have Ridden In
PhredValk
« Reply #6 on: February 03, 2013, 07:52:43 PM »
Gee, thanks Steve. The tank is my next project.. Grin Grin
Fred.
VRCCDS0237
