November 19, 2025, 01:06:52 PM *
Author Topic: Help -- Use of RideOn  (Read 2835 times)
Six Packer
« on: June 21, 2009, 02:57:37 AM »
I purchased the 3 tube kit from RideOn to use in my tires.  However, I am having a problem in getting the darn stuff into the tires.  When I use the instructions on the bottle I can't get the stuff to go into the tire thru the plastic tube even tho I am using both hands to squeeze.  Like trying to milk a dry cow.  Is it me in my older age or is there something I am missing in the application.   I know some of you guys have used RideOn so give me a little help please........
« Reply #1 on: June 21, 2009, 04:05:15 AM »
Did you remove the valve core??
Master Blaster
Deridder, Louisiana
« Reply #2 on: June 21, 2009, 05:42:03 AM »
Might be easier to break the bead on one side and put it in that way.  I have it in my I/S and I bought the one that came in a cauk gun tube.  No problem getting it in that way.
John U.
Southern Delaware
« Reply #3 on: June 21, 2009, 08:27:30 AM »
I had the same experience with getting Ride-On into the tire with the squeeze bottles.
My hands hurt the next day. The only idea I can offer is a big pair of channel lock pliers and a rag or something to prevent destruction of the bottle. I haven't tried it but will the next time. Of course uou can't squeeze too hard or the tube will blow off the bottle.
Whatever method you use, you need to sqeeze then let up to let the air returen to the bottle, then squeeze again.
Let us know if you figure out a better way.
TomT
Our very first day on the Valk up on the BRP!
Lynchburg, Virginia
« Reply #4 on: June 21, 2009, 10:12:55 AM »
I cheated and went to the local dealer and had them install it. Took about 20 minutes and cost $25.00 for both tires. Then I was told I HAD to go out and ride for a minimum of 30 minutes for it to allow it to seat. No problem. I love the way the stuff seems to maintain the tire pressure and balance of the tires!
Good luck!
Tom in Lynchburg, VA
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #5 on: June 21, 2009, 06:18:31 PM »
Stupid question, but did you cut the top of the bottle off first? Otherwise, just slow down keep squeezing and it isn't that bad of a job. I may have my own problem though; I installed it yesterday anticipating getting the bike on the rode, and due to several circumstances, it will have to wait at least a week now before I can ride. Hope it doesn't "set" or I'll be pulling tires.
Dress for the slide, not the ride. ATGATT
VRCC #2505
« Reply #6 on: June 22, 2009, 06:58:22 AM »
Run hot water over the tube for 10 minutes, will do wonders. Hoser cooldude
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #7 on: June 22, 2009, 07:53:53 AM »
Now that's a great idea. Never thought of it. Thanks!!
VRCC #2505
« Reply #8 on: June 23, 2009, 05:05:57 AM »
Glad I could help. hoser  Smiley
« Reply #9 on: June 23, 2009, 05:18:38 AM »
+1 hoser
, take out the valve core, stem should be at 6 oclock, cut the top of the bottle just below the line, open then close the top and shake it if it dont flow for you, kinda like starting the heinz ketchup off and tap it from the bottom.    Warm ride on flows better for sure.
Ive been using it for years and so far so good   9oz in front and 10 in year
You need the car tire formula for a car tire just in case you have one.
Six Packer
« Reply #10 on: June 25, 2009, 10:01:49 AM »
Thanks for the replies.  I am going to heat up the bottles in a pot of water--just like warming a baby's bottle and then try to use.  The stuff is congealed in the bottle with no air getting to it.  Surely they package this stuff when its hot.
