July 06, 2025, 06:26:19 PM *
Author Topic: Hippity-hop...  (Read 1902 times)
FLAVALK
Winter Springs, Florida
« on: June 21, 2009, 10:02:00 AM »
...and I an't talking about the Easter Bunny. Went for a 150 mile run today on my new front Avon Cobra and the front end hops around 35 mph...crap!  Angry
It seems to only do it between 35-40 and then smooths right out. I was running 42 psi and wondering if this might be to high for this tire, or is the tire bad? Besides that little issue, I like the tire. It makes the front end seem lighter and it the bike falls effortlessly into a turn.
The tire I replaced was an Avon Venom. 42-psi for 20,000 miles with no issues.
Seems that I read here about someone else with a 35-mph hop with the Cobra.
« Last Edit: June 21, 2009, 10:05:50 AM by FLAVALK » Logged
Disco
Republic of Texas
« Reply #1 on: June 21, 2009, 11:00:00 AM »
This sounds like a balance issue.  I can't see how pressure would be the cause.  Is it balanced with either lead or dynabeads?  I have 2 ounces of dynabeads in my Venom front and it's as smooth as glass.
« Last Edit: June 21, 2009, 11:01:32 AM by Dave in Frisco (TX) » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
FLAVALK
« Reply #2 on: June 21, 2009, 11:20:19 AM »
It's balanced with lead. Tire mounting is the only thing that I don't do in the routine maintenance of my bike. Guess I will have to start.
« Reply #3 on: June 21, 2009, 11:42:19 AM »
If you can get the front off the ground it's easy to check the run-out of the tire.  And I don't trust bubble balancing if that's how it was done.
And yes, if there is a tire construction problem, lower pressure in the tire will tend to minimize any bouncing. A harder tire will make irregularities more pronounced.
FLAVALK
« Reply #4 on: June 21, 2009, 03:53:47 PM »
I took the wheel & tire to a local shop and let them mount & balance it, so I don't know how it was done. Guess I'll remove the wheel and balance it myself...should have checked it before I put it back on the bike.  Angry
Disco
Republic of Texas
« Reply #5 on: June 21, 2009, 06:00:56 PM »
Good point, Ricky.   cooldude  I didn't think of a faulty tire at new or 150 miles.
But, if memory serves, there have been some reports here over the last year or so about Avons failing prematurely.
78 CB550K
dcfan2
« Reply #6 on: June 23, 2009, 07:16:08 AM »
I had the ame problem with an avon venom.about 35mph would get a rythmic bounce.Pulled tire and had balance checked-spot on.Tire pressure made no difference.Tire had about 8 grand on it and still half of tread left.Also developed some handling issuses--possible belt broke?.Changed  to a Metz 880 and no more bounce.Possible break down in tire?
« Reply #7 on: June 23, 2009, 10:34:19 AM »
I And I don't trust bubble balancing if that's how it was done.
they have to keep those bubble balancers calibrated.
I never heard of anyone needing to calibrate gravity  coolsmiley
Here's a picture I made when I did my first balance job with a static balancer...
