February 06, 2026, 09:35:12 AM *
Author Topic: Interstate radio memory  (Read 978 times)
bikerboy1951
Grand Forks, ND
« on: February 10, 2013, 05:06:25 PM »
I have an Interstate that I purchased last fall.  I was going to program the radio, but need to remove the battery in the spring for some wiring projects.  Does the radio retain its memory when the battery is removed.  If so, there is no reason to fool with it now.
Brad
3W-lonerider
Shippensburg Pa
« Reply #1 on: February 10, 2013, 05:26:01 PM »
as soon as you disconnect the battery you will lose the memory.
