February 06, 2026, 09:35:00 AM *
Author Topic: wheel damper bolt broken  (Read 1716 times)
Shydog
Dresden, Ohio
« on: February 11, 2013, 02:45:15 PM »
Hello all,    I decided to tear into the fat lady, '00 interstate, and removed the rear wheel, final drive, and driveshaft. 30k on the ole girl. All the splines were in great shape and well lubed. I did change the dampers and after replacing those, I twisted off one of the damper plate bolts. My darn torque wrench was cold after bringing it in from an outside shed, and I didn't wait for it to warm up. Anyway the other 4 bolts were installed ok. Question is will the plate be ok with just the 4 bolts, or should I remove the plate and try to extract the bolt, twisted off just below the surface of the wheel, with an easy out kit? Any other suggestions?
Shydog
E. central Ohio
Daniel Meyer
The State of confusion.
« Reply #1 on: February 11, 2013, 02:54:49 PM »
Yes and no.
I think the plate will stay in place...
...but I'd replace the bolt.
Sorry, not much help I know LOL! Smiley
CUAgain,
Daniel Meyer
Red Diamond
Beaumont, Texas
« Reply #2 on: February 11, 2013, 02:58:59 PM »
Try a left handed drill bit, if it hasn't bottomed it may just back out.
« Reply #3 on: February 11, 2013, 04:23:35 PM »
I too would replace it, even though it probably won't bother leaving it alone. However you decide to remove the old stub, make sure you start the drill in the exact center. That way if the left twist drill or easy-out doesn't work [ hopefully it should though] then you drill enough to re-tap/chase the original size.
vanagon40
Greenwood, IN
« Reply #4 on: February 11, 2013, 05:53:51 PM »
I would make an effort at removing it and replacing it, just because I wouldn't like having a wheel with a defect.  That said, I cannot imagine that anyone would ever notice the missing (broken) bolt.  I'll be more assertive than he previous responses, I don't just think the plate will stay in place, I am certain the plate will stay in place.
Here is my thread on the subject:   Click here.
« Last Edit: February 11, 2013, 05:57:15 PM by vanagon40 » Logged
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: February 11, 2013, 06:44:01 PM »
There has been some previous discussion about whether or not the damper bolts are torque-to-yield bolts. I did some experimenting and found that when the bolts are torgued to the specs in the manual, they permantly stretched by more than .030 inch. They continued to stretch each time I torqued them. You cannot torque a bolt that is stretching. It will eventually break as you have found.
Two choices after you remove the broken bolt. Get new damper bolts and torque to spec - or re-use the old bolts with blue lock-tite and snug them down good without the torque wrench.
Good luck
« Last Edit: February 11, 2013, 07:18:07 PM by indybobm » Logged
So many roads, so little time
VRCC # 5258
Shydog
Dresden, Ohio
« Reply #6 on: February 12, 2013, 05:48:13 AM »
Thanks all for the responses to my problem. I will try to remove the twisted off bolt with an easyout or left handed drill bit. Will stop by the local auto zone and see what they have available. I wonder if they would have bolts that would replace the used ones on the damper plate?
« Reply #7 on: February 12, 2013, 08:18:54 AM »
I can't really see the need to torque those bolts anyway!
The plate is held in by the wheel when you clock the plate and all the bolts do is to keep the plate from turning.
A nominal tightening and some thread locker is all I can see being needed.
A torque wrench is probably the biggest contributor to broken bolts and screws.
In the wrong hands it certainly is.
Daniel Meyer
« Reply #8 on: February 12, 2013, 08:34:33 AM »
Particularly on the small and low torque fasteners. The big wrench won't be accurate at low values, and the inexpensive small wrenches (harbor freight etc) are grossly inaccurate...often off by 2-300%...
CUAgain,
Daniel Meyer
« Reply #9 on: February 12, 2013, 08:41:47 AM »
I agree with the torque wrench comments, plus, some folks really don't know how to  handle one. I'm not saying Shydog doesn't know how to use one, I'm just saying that some don't.
john
tyler texas
« Reply #10 on: February 12, 2013, 05:54:45 PM »
I twisted off one of the damper plate bolts.  " My darn torque wrench was cold "             2funny
                sears craftsman ... left handed drill bit and e-z out all in one ....           cooldude
     like a dream come true ....                coolsmiley
vrcc # 19002
fordmano
San Jose, CA.
« Reply #11 on: February 12, 2013, 10:05:22 PM »
Damn, when I changed out my dampeners I managed to over torque one bolt felt the threads starting to pull and stopped before I broke anything. Luckily that was the first bolt it seemed like the torque wrench was set to click at too much torque and I checked the number and it was. I think the book says something like 47INCH pounds and I had the torque wrench set to 47 FOOT lbs,,, no clue what made my head read the number wrong but I did...
A torque wrench is not a toy its a tool and in the wrong hands can be VERY dangerous...
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
