February 06, 2026, 09:35:00 AM
parts for final drive and rear end.
Topic: parts for final drive and rear end. (Read 1312 times)
jimmytee
Elizabethtown,KY
February 13, 2013, 02:22:42 PM »
Ok, I've done some searching, got a clymer manual and am trying to be certain I order all the appropriate parts needed for my drive line maintenance. Splines are good, have not disassembled the drive shaft from the pumpkin yet. There are some must haves for reassembly outside of any worn parts, just want to be sure I'm covering them all. Some of the parts aren't listed in the hdl parts breakdown but are at cheap cycle parts. Any opinions or input.
Thanks jim
whitestroke
San Pedro, Ca.
Re: parts for final drive and rear end.
February 13, 2013, 06:08:00 PM »
If I remember correctly orings and thrustwasher and grease where the only things needed for my service. Really didn't even need the thrustwasher as the new one was the same thickness.
Anyway this thread covers parts I needed with pictures
http://www.valkyrieforum.com/bbs/index.php/topic,43210.msg412850.html#msg412850
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
jimmytee
Elizabethtown,KY
February 13, 2013, 07:47:54 PM »
Thanks, that's what I was gathering from the manual. Appreciate the link
PhredValk
Edmonton, Alberta, Canada
February 13, 2013, 10:38:43 PM »
3 O-rings and a thrust washer, your choice of moly paste or grease, decent torque wrench. Carolina Bike and Trike has the O-rings, 5 sets of them under $15.
http://www.carolinabikeandtrike.com/ORings.htm
I also got the intake O-rings, as I'm planning on polishing the intakes.
Fred.
Last Edit: February 13, 2013, 10:40:25 PM by PhredValk
VRCCDS0237
February 14, 2013, 08:34:04 AM »
A new thrust washer is only required if the one you are presently using is degraded.
They normally do not need replacing.
