July 06, 2025, 06:13:15 PM *
Author Topic: carb sync  (Read 1970 times)
art
Grants Pass,Or
Grants Pass,Or
« on: June 21, 2009, 05:35:53 PM »
I tried to sync.the carbs with a gage that I bought from harbor freight but the needle swings all over the place .the vac. is not steady  it  puffs air out then draws vac. so that I cannot get a reading.Any ideas on this ,has this been a problem with anyone else or is it normal? Art
Dave Weaver
Seymour, IN
« Reply #1 on: June 21, 2009, 05:48:24 PM »
It is normal, Art.  Take a pair of needle nose pliers or vise grips and squeeze some pressure on the vac. line below the gage until needle smooths out.
Do unto others as you would have them do unto you.
BamaJack
McCalla, Alabama
« Reply #2 on: June 21, 2009, 06:44:51 PM »
I use some valves from a fish tank in line. Start with the valve open and slowly close it until the gauge stops wagging.
Jack in Bama - vrcc#10322      Phyllis (PeeK) in Bama - vrcc#19668
2000 I/S Super Valk                   2000 Tourer
1999 Interstate                          2003 Standard
Ken Tarver
North Mississippi
« Reply #3 on: June 21, 2009, 09:00:40 PM »
fold over your tubing and use a clothes pin and adjust till the needle stop twitching
« Reply #4 on: June 22, 2009, 03:45:45 AM »
What your seeing is normal and what the boyz told you is correct.. A vacuum gauge that has a damper screw slows the pulses in the same manner, it just pinches the tube.. You want to pinch the tube just so the needle wiggles a little bit..
Dag
Country Rep. Norway
« Reply #5 on: June 22, 2009, 05:05:29 AM »
Its not normal....
I have built several carb tune units and I have never had that problem.
All liquid filled vacuum gauges should have a rubber tip on top.
You have to either cut the tip or take the rubber top off when using the gauge.
« Last Edit: June 22, 2009, 05:18:33 AM by Dag » Logged
art
Grants Pass,Or
Grants Pass,Or
« Reply #6 on: June 22, 2009, 09:09:11 AM »
thanks I'll try that an see
Ken Tarver
North Mississippi
« Reply #7 on: June 22, 2009, 09:02:16 PM »
now look what you gone and done with that case! Now I see a rebuild here in the shop....I like it Dag, that is nice.
Ken
