January 29, 2026, 12:56:59 AM
speedo is out
Topic: speedo is out (Read 1951 times)
rfsrider
speedo is out
June 21, 2009, 05:42:12 PM »
Had the front wheel off to rebuild the forks. This is not the first time I have had the front wheel off. Installed everything like I have before and my speedometer is out now. I know from past riding that at 3,000 rpm, in 5th gear, I am doing 100kph. Now, at 3,000 rpm, in 5th gear, it only registers 70 kph on the speedo. Took the speedometer drive unit off and noticed some of the teeth on the gear are pooched. Anyone run across this before? Could this cause a difference in my speedometer? I should mention I ride a 2000 Valkyrie Interstate.
Any insight would be greatly appreciated.
shortleg
maryland
Re: speedo is out
June 21, 2009, 07:02:33 PM »
I would think that if any of the gears are not mateing then that would
or could have an effect on your speedo.
Shorteg[Dave]
B
Capital Area - Michigan
Re: speedo is out
June 22, 2009, 08:39:43 AM »
I had recurring speedo problems that didn't go a way until I replaced the front bearings even when replacing the speedo gear and assembly. The only thing I can figure is the bearing wasn't bad enough to notice (by feel or handling) but had enough slop to interfere with the sensor getting a good read. It's been over a year since replacement & I haven't had any speedo problems since.
rfsrider
Re: speedo is out
July 01, 2009, 05:22:50 PM »
Installed the new gear and the speedometer works fine now.
