January 28, 2026, 11:00:15 PM *
Author Topic: Handlebar risers  (Read 1960 times)
RLD
'99 I/S Red/Black
Eden Prairie, MN
« on: June 21, 2009, 06:14:25 PM »
Can anyone tell me a supplier for "shorter" risers? I'd like too shorten them a couple of inches. Right now they measure about 3" from the base to the center of the bars. Has anyone just cut them off and re-tapped them? I would assume they are the same as some other bikes out there, I just ran out of time to measure the bar diameter and check the bolt size. Thanks a bunch!!
Dress for the slide, not the ride. ATGATT
VRCC #2505
Duct Tape
Man-servant of QOTFU
Sugar Land, TX
« Reply #1 on: June 22, 2009, 03:41:37 AM »
I haven't seen shorter risers.  I suppose you could cut them off, but be sure it's a good square cut.  It's a metric bolt.  I believe 12 mm.  I'm not sure of the handle bar size, but risers for 1" bars will work with the OEM bar.  I installed risers that required 1/2" bolts, so just had to drill out the triple tree mounting plate a little.
Rog
"Duct Tape"
« Reply #2 on: June 22, 2009, 06:08:18 AM »
You might want to check out other handbar options......such as "beach" bars that would be at a lower height.
